  1. yura999
    yura999 New Member
    327Coins
    Thank you for your prompt response. Would you like to know if simtools and simhab will work together? the simulator chair is tied to simtools, and the shakers are tied to simhab (two different ports and two arduino uno).
  2. yobuddy
    51,557Coins
    Hi @yura999
    I think it will work for memory mapped and memory hooked games, but udp output games will probably send the data to either of the two apps, but not both.
    But its worth a try!
    Take care,
    153,986Coins
    +11,162 / 57 / -2
    You can have a port conflict but get around that with the SimHub port forward setting.
    You could just use SimTools GameVibe companion app instead of SimHub.
    The GameVibe manual information is here: https://www.xsimulator.net/community/threads/gamevibe-manual.11358/
    153,986Coins
    +11,162 / 57 / -2
    It may also help if you post a video showing the problem.
  5. yura999
    yura999 New Member
    327Coins
    Hello friends. I decided to try to connect the simtools program and the Slim Hub program at the same time. Unfortunately I didn't succeed because the Slim Hub requires changing the file to transmit telemetry cfg.txt in the LFS game. When the file cfg.txt SimHub was changed, and the telemetry was received in the SimHub program (the blowers worked), but the telemetry is not received in simtools, although simtools connects to the LFS game (lit in blue, you can run tests and settings in the menu). If the LFS game is patched again, SimHub stops connecting to the game, but simtools is now working properly. (I currently have two Arduino Uno R3s connected to two different ports). How can this be solved?
    153,986Coins
    +11,162 / 57 / -2
  7. MagicEdge
    MagicEdge Active Member Gold Contributor
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    Why is not recommended to run 3 motors on 6 DOF simulators with SMC3 available? 2 motors are recommended using 3 Arduino Uno R3.
    153,986Coins
    +11,162 / 57 / -2
  9. hannibal
    hannibal Active Member
    4,492Coins
    why.jpg 83902 hey a year after build my 6dof.
    i am using a sabertooth and arduino uno combo powering 2 motors.
    i am looking at the SMC3 utility.
    and i see that on Motor 1, the yellow line is closer to the top red line..
    but on Motor 2, the yellow line is closer to the bottom...but both have the same settings on SMC3..
    I have no idea why this is..
    need your help
    @noorbeast @SilentChill @BlazinH @Pierre Lalancette @wannabeaflyer2
  10. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,043Coins
    3DOF, DC motor, Arduino, 6DOF
    If I remember correctly, the green line is the position feedback that tries to go to the middle. So since it is below, it gives power to the motor to bring it back to the center. The other one is there, so, no need to send power to the motor.
    Correct me if I am wrong people.
    Pierre.
  11. hannibal
    4,492Coins
    when i did was closing up the build of the power and driver parts and putting it online back then.. i noticed i had to reverse the wires between the ampflow motor #2 into the sabertooth motor 2 terminals, in order to make the the green line move as desired... i wired the pots for motor one and two the same..maybe i have to reverse them? or maybe i have something else wired wrong? followed sixdegreesofflight and @wannabeaflyer2 's build...
  12. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,043Coins
    Do you have problems with your rig? If they were connected upside down, you would know it.
  13. hannibal
    4,492Coins
    everything is working now.. i associated wrong comm port with SMC3 utility....
  14. hannibal
    4,492Coins
  15. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,043Coins
    This is not the place for a conversation, but for a quick recap, I didn't do anything with my rig and my VR for months. I was busy working and doing other project. Did not have yet time to play Outrider which I worked on. I guess I have more fun building rigs that playing them. I have new ideas, but I don't have the time or the budget.
  16. hannibal
    4,492Coins
    i hear you
    i recently built joysticks that resemble miniguns.
    im trying to get back into motion sim. excited for the new DCS World updates.
    i miss all you guys, wannabeflyer, histoker, it was an endeavour to build my 6dof following u guys
  17. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,043Coins
    I might get back when elite dangerous odyssey will come out.
  18. ahoenksiluman
    ahoenksiluman Member
    indonesia
    89Coins
    do someone know how to use a3 channel to control the feedback gain..??
    i currently build 2dof rig mover...
  19. absyfadhel1
    absyfadhel1 Active Member
    bahrain
    556Coins
  20. motiondynamics
    motiondynamics Member Gold Contributor
    1,235Coins
    2DOF, 3DOF, DC motor, AC motor, SimAxe, Arduino, Motion platform, 6DOF
    Hello to all of you dear simulation colleagues.
    I'm going to start using SimTools shortly because a lot of my friends talk about it very well.
    I have never used the SimTools interface and I have never used the PID code (SMC3) because for a few days I have been trying to understand what I need and what to download.
    I am having difficulty knowing which version of SMC3 I should use for my electronic system (Arduino Uno R3 + Monster Moto).
    I think I understand that in the code I have to change a line (MODE1 or MODE2) to "MODE1" because my system requires 3 wires: 1PWM and 2 DIRECTIONS.
    QUESTIONS
    • Is the last (newest) version of the official SMC3 code I can use in MODE1 SMC3 v1.0?
    • In the code "SMC3" I have read 25Khz for Motor 1 and Motor 2, I have read 31Khz for Motor 3. Where is it possible to choose the frequency 25Khz and 31Khz? Where can I select the frequency, from SMC3Utils or Simtools?
    • In the SMC3 v1.0 code I saw "A5 - Motion scaler pot input". I would like to know what the A5r pin is for?
    I don't have very clear ideas, I would be grateful if you give me these answers because I want to start using Simtools right away and I have to purchase the license.
    Thank you
