(BUILD) 2DOF rig mover as cheap as possible but as strong as possible
Discussion in 'DIY Motion Simulator Projects' started by ahoenksiluman, Nov 23, 2020.
  1. ahoenksiluman
    ahoenksiluman Member
    indonesia
    89Coins
    im new to this dof build, but ihave experience in DIY steering wheel base build using arduino/stm32 and DC motor
    this time, i try to the nex level of DIY build, but i try as cheap as possible but it need to be as strong as possible
    in this time, i already build the controller/brain. using arduino uno and bts7960/ibt2 for motor driver.
    and, for the actuator, ihave plan to use industrial worm gearboc and custom coupled with my1016 250w DC motor.
    and this is my design...
    i hope the motor fast and strong enough...
    for now, i just wait the part to come...
  2. RacingMat
    21,047Coins
    nice aviation plugs!
    these bike motors are current hungry! @Lebois burnt some ibt2 drivers if I remember correctly... :(
    you should double them for 1 motor and add heat sinks and a fan!
  3. Lebois
    Math teacher
    2,565Coins
    be prepared for a nice and smooth burning smell ^^
    I now drive this motor with this driver that is barely enough... Check my website to see how to wire it.
  4. ahoenksiluman
    indonesia
    89Coins
    the only way is to try it when the parts come...
    usually i drive ibt2 around 20-25A with no problem...
  5. ahoenksiluman
    indonesia
    89Coins
    some update for my project...
    all tested normal without problem, but i wanna change potentiometer to hall sensor...but still doesnt have time yet...
  6. absyfadhel1
    absyfadhel1 Active Member
    bahrain
    550Coins
    did you complete it?
  7. ahoenksiluman
    indonesia
    89Coins
    have lots project to do, and now one step closer to finish it...
  8. ahoenksiluman
    indonesia
    89Coins
    more update...
    i've already tested my actuator attached to my rig but only using 12v ATX PSU, and it work well. and i still have plenty of room of adjustment because i have lots of hole im my actuator's arm, so i can move it if it can't handle the weight.
    and this is some vid, sorry for blurry vid, i only use old phone to record it.
  9. ahoenksiluman
    indonesia
    89Coins
    some action from low budged setup...
    it works well with 19v 20A PSU, but i give it 22v 30A to give some headroom if it needs some power...
  10. MarcoT
    MarcoT New Member
    15Coins
    I'm planning to use the same motor and wormgear reducer. Is that an NVR30 or 40? How di you couple the motor shaft to that reducer? Whoul you still suggest the same combo?
    Thanks!
