Codemasters F1 2020 Plugin v2.0
SimTools plugin for Codemasters F1 2020
  1. pfm21
    pfm21 pfm21 build 3dof dinamic
    374Coins
    look in the previous posts I published the settings to make everything work with F1 2020
  2. Martin.Berger
    Martin.Berger Member
    216Coins
    Hi @pfm21
    Aren't you talking about simhub?
    Sorry nur i cannot finde any settings rereading all your Posts.
    Thanks for Help
  3. pfm21
    374Coins
  4. Tom:))))
    Tom:)))) New Member
    30Coins
    Only "pitch" works, ive tested all other functions under all UDP types and nothing works except Pitch when using Legacy UDP. I'm currently using 2DoF, PT Actuators. Any help?
  5. pfm21
    374Coins
    Right click ixon game manager and go tuning center
    After click on capture, reset and run one lap on Monza.
    When finish lap select save setting
    Stop capture
  6. yobuddy
    51,529Coins
    The Tuning center is in Game Engine actually, i'm sure its just a miss-type but i wanted people to know.
    Take care!
  7. pfm21
    374Coins
    Yes. Sorry
  8. Tom:))))
    Tom:)))) New Member
    30Coins
    i attempted to calibrate the tuning center in monza, still got the same result. the tuning center is gathering data in all DoF, but my actuators do not respond to anything except "pitch" values. ive tried isolating each DoF in the axis assignments, only pitch is responsive
  9. bruno1210
    bruno1210 schumi06
    103Coins
    UDP FORMAT legacy mode NOT 2020 and f1 2020 dx11
  10. Tom:))))
    Tom:)))) New Member
    30Coins
    I'm running DX11 and Legacy format, calibrated tuning center in monza, still doesnt work. i cant figure out why tuning center is displaying values accross all DoF, but those values arent transmitting to the actuators, aside from pitch
  11. pfm21
    374Coins
    Have setting like this?
  12. pfm21
    374Coins
    Have select 2018?
  13. bruno1210
    bruno1210 schumi06
    103Coins
    Yes select 2018
  14. pfm21
    374Coins
    On smc3 "motion" your Dof works on both sides?
  15. lupotto
    lupotto New Member
    - 120Coins
    Can i use the F1 2020 plugin or do i have to wait for the new f1 2021 plugin to use simtools?
  16. pfm21
    374Coins
    I think that the new plug-in is necessary because inside it there are the instructions to recognize the game when it is running.
  17. bruno1210
    bruno1210 schumi06
    103Coins
    Good evening,
    yes you have to wait for the games to be tested with the new plug-in.
  18. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, f1 2021 only works in dx12 versions strongly the plugin thank you.
  19. ludo22420
    ludo22420 Member
    206Coins
    hello does this plugin work on ps4 thank you
  20. ivan jack
    ivan jack Member
    412Coins
