MY own 2 dof diy
Discussion in 'DIY Motion Simulator Projects' started by absyfadhel1, Apr 17, 2020.
  1. absyfadhel1
    absyfadhel1 Active Member
    bahrain
    556Coins
    and this happen when i launch smc3
    153,866Coins
    +11,152 / 57 / -2
    What hardware are you using?
  3. absyfadhel1
    bahrain
    556Coins
    I solve it, the problem was there was broken cable, lol,
    but i have ne issue now , the motor work great with 600w psu, but when i increase the pwmax,pwmin in smc3 the motor not moving why? the psu is good and the motor 300w, and the motor not connected to body so no weghit, but when the pwmax and min set in 70 its work until i increase it its stop , helppppppp
    153,866Coins
    +11,152 / 57 / -2
    Can you please post some hardware pecs and pictures, we are flying blind without knowing specifically what you are using.
  5. absyfadhel1
    bahrain
    556Coins
  6. absyfadhel1
    bahrain
    556Coins
    the problem is when the setting in the circle below 70 motor work but when above nothing move
    153,866Coins
    +11,152 / 57 / -2
    They look to be IBT2s, so before we get into other possibilities can I please confirm are you using Mode 2 in the SMC3 code?
  8. MarkusB
    4,215Coins
    The PWMmin and PWMrev values are quite high. Have you tried to set them all to zero and then only increase PWMmax, as it is described in the SMC3 tutorial?
  9. absyfadhel1
    bahrain
    556Coins
    yes i do
  10. absyfadhel1
    bahrain
    556Coins
    this is the problem
  11. hannibal
    hannibal Active Member
    4,492Coins
    your pot looks super noisy... have you tested the movement of the motor with the pot separate?
    kind of like what this guys is doing...
  12. absyfadhel1
    bahrain
    556Coins
    yes the pot work great and the motor move good without weight , but when i put my hand in the motor to get force the motor shutting down and not move until i unplug and replug the usb cable
  13. absyfadhel1
    bahrain
    556Coins
    when i test the motor and check force via putting the cable direct to psu not to the ibt board the motor push perfect but via the ibt2 board no force, this what i tried:
    change wires,
    change psu,
    change pot,
    change arduino and ibt,
    check in another pc.
    help please
  14. absyfadhel1
    bahrain
    556Coins
    is there any powerful board to replace it with ibt-2?
  15. absyfadhel1
    bahrain
    556Coins
    Update: i tried to double ibt-2 for motor and the motor worked above 200 PWMrmax , put when i try to force the lever by my hand the ibt-2 cut the power from the motor so the issue not solved! help
  16. absyfadhel1
    bahrain
    556Coins
  17. iLLuac4
    iLLuac4 Active Member
    891Coins
    Interesting I have the same problem. It is not a deal breaker because I have leveled the seat so not so much force is needed but if I force the force to the seat i can also trigger shuts down of the motor. After I reset the arduino (i have made a reset button) it powers it up again.
    Does this happens to both motors? Could it be that it is only one of the IBT-2 weaker?
    This was the post i have made:
    https://www.xsimulator.net/communit...nd-windows-utilities.4957/page-96#post-208566
    and this is the build:
    https://www.xsimulator.net/community/threads/simlab-gt2-to-2dof-conversion.13948/
    I did not try other PWM drivers.
    My suggestion would be:
    - try revesing the polarity of the motors and also pots
    - try other ibt-2 (batch difference)
    - try other PWM driver (avoid moto monster)
    P.s.:
    Similar problem
    https://www.xsimulator.net/community/threads/6-dof-350w-motors-with-ibt-2-43a-h-bridge.11538/
    https://www.xsimulator.net/community/threads/racing-6dof-stewart-platform.13057/
    https://www.xsimulator.net/community/threads/bolt-on-2dof-project-with-12v600w-motors.13963
  18. absyfadhel1
    bahrain
    556Coins
    hi, as in title , where to buy 100a h bridge 12v motor driver?
    like this one?
  19. absyfadhel1
    bahrain
    556Coins
    when i tried to tunning center for no limit 2 after save setting the motor go forward and backsword fast and make crash, but in lfs and assetto corsa its fine help!
    153,866Coins
    +11,152 / 57 / -2
    Sounds like the TC values are way too low, did you capture the Max and Min values first?
