Question Can I use Logykal box with SimTools?
Discussion in 'SimTools compatible interfaces' started by DoMRace, Apr 22, 2021.
  1. DoMRace
    DoMRace New Member Gold Contributor
    - 3Coins
    Hi guy’s,
    Im new on this forum. I bought a JCL v3 with 2 SCN6 40kg 100mm with the logykal box and the lince software. I add a traction loss on my v3 with a SCN6 40kg 150mm and I really don’t like the effect of the traction loss. I discover yesterday the Simtools software and Im interrested to test it.
    I would like to know if it’s possible to use the Logykal box with SimTools? Otherwise I think I will have to buy 3x converter USB RS485?
    thank you for your help
    152,265Coins
    +11,066 / 56 / -2
  3. DoMRace
    - 3Coins
    Thanks noorbeast for the reply. I found nothing on the web about this and Im afraid to do some test without the knowledge.
    I don’t know why the converter rs485 cable is so expensive? I found one on the logykal website but it’s 100 euros each and I need 3 cables.
    I prefer to find a solution with the Logykal box but if I have no answer, I will looking for the usb converter.
    152,265Coins
    +11,066 / 56 / -2
  5. DoMRace
    - 3Coins
  6. JCDionne
    JCDionne Custom Sim build
    GM
    Canada
    - 29Coins
    4DOF
    I am using Logykal box with SimTools no issues
  7. hideki
    hideki Active Member
    Spain
    - 208Coins
    2DOF, SCN5
    YES you can. I have a friend with one logykal box and Windows 10 sees the COM ports just as Simxperience does, To save your time, use the logycal software to notice what port is each actuator. For example: left actuator=port7 right actuator= port8 and then put them in your Game Engine Interface Settings and Axis Assigments and you are good to start.
  8. DoMRace
    - 3Coins
    Thank you @JCDionne for the info. Please could you share your default setting? I maybe have a problem with my settings. When I started the Simtools software, the 3 actuators are detected but I can't test it in the output testing.
    152,265Coins
    +11,066 / 56 / -2
  10. DoMRace
    - 3Coins
    let me know if you need more pics.
    Thank you
  11. DoMRace
    - 3Coins
    Important thing you should know: I take the info of my 3 actuators comPort in my logykal log. I attach a picture. My 3 actuators are plug in my Logykal box and I have one usb cable between my Logykal box and my PC.
  12. DoMRace
    - 3Coins
    axis pic missing
  13. DoMRace
    - 3Coins
    any idea?
  14. hideki
    Spain
    - 208Coins
    2DOF, SCN5
    what do you mean by axis pic missing?
  15. DoMRace
    - 3Coins
    One
    One picture was missing in my last post
  16. hideki
    Spain
    - 208Coins
    2DOF, SCN5
    Ok So what is your situation? When you start game engine, do the 3 motors move? They should test and go to O position.
  17. DoMRace
    - 3Coins
    Yes when I start the game, the 3 actuators move and go to 0 position.
  18. hideki
    Spain
    - 208Coins
    2DOF, SCN5
    Hi. You are good to go, then. Just try and error until you get it right. First I would check other member's posts to copy what they do.
    I dont have a 3rd actuator for Traction loss but I dont think you put the extra1 movement in the DOF1 sway colum. Doesnt it have to go in a new one? Anyway, you are very close now so just dont give up and keep trying.
  19. Ethanolcoca
    Ethanolcoca New Member
    26Coins
    Hi, i have the same problem. I have a Logykal box with 2 SCN6, and with Simtools, only one actuator is moving. Here is the log from Lince, and also the settings i put in Simtools.
    Thanks for you help.
  20. hideki
    Spain
    - 208Coins
    2DOF, SCN5
    Try com 4 and 5 Never com 1
