PT Actuator 4 Dof +TL Fault code
Discussion in 'New users start here - FAQ' started by SOUTHROD, Apr 25, 2021.
  1. SOUTHROD
    SOUTHROD New Member Gold Contributor
    39Coins
    4DOF
    Hi all new member here from Australia,just finally finishing up my Sim Build, and powered up yesterday the PT Actuator side of it to test,Ive gone through all the steps using Barry from Sim Racing Garage's how to on youtube plugged the Thanos controller in and the rig went into what I assume was a test mode,it all lifted the full height and the TL went to one side,but then the left rear actuator made a jolt and a AL-06 Code came up on its corresponding AASD-15A servo,found out its a overload 2 fault code, what would cause this is the servo or actuator stuffed,help.?
    Shane.
    153,986Coins
    +11,162 / 57 / -2
  3. Thanos
    Electronics Engineer
    2,908Coins
    Perhaps the max motor speed on your servo drives is not correct. Seen many times PT-ACTUATOR AASD-15A servos being shipped with Pn051=5000 (yes 5000 RPM).
    Just set Pn051=3000
    And perhaps do a check on the rest parameters as well:
    Thanos
  4. SOUTHROD
    39Coins
    4DOF
    Hi Thanos thanks for your reply yes I have done these checks initially and have checked them since (all are on 3000) the problem as well,all were set to 5000 initially but I changed them to 3000 as suggested in your AMC instructions,it is strange that all the actuators will move in the function mode manually so no problem there its only once I plug the AMC controller in and it goes into test mode that it does this fault code on the left rear,maybe the Servo is faulty.?
    shane.
  5. SOUTHROD
    39Coins
    4DOF
    all good now, dont know what i did but its parking and moving ,now Im trying to update the firm ware on the AMC Controlleras mine does not have the spike function, any one help with that,I know its on git hub but which file is it theres a lot of them and I have no idea which one to download file or how to download it really need ahold my hand type how to for dummys like me.
  6. Thanos
    2,908Coins
    If you bought the AMC-AASD15A controller before 2021, chances are you have the Atmega1280 chipset. In this case download, extract and use this firmware:
    https://github.com/tronicgr/AMC-AASD15A-Firmware/blob/master/Latest_firmware/enc_1280_6dof_AMC_AASD15A_v2_11_beta_fix5_RGB.zip
    And of course download the AVRUBD utility to update the firmware from here:
    https://github.com/tronicgr/AMC-AAS...t_firmware/Firmware bootloader Utility 52.zip
    Instructions for the procedure are on the github page that include a video link as well:
    https://github.com/tronicgr/AMC-AASD15A-Firmware/tree/master/Latest_firmware
    Thanos
  7. SOUTHROD
    39Coins
    4DOF
    Ok thanks Thanos, much appreciated Im running Sim Racing Studio,do I need any other downloads for that.?
    Shane
  8. Thanos
    2,908Coins
    Perhaps download and update to latest FTDI drivers as well (USB interface):
    https://www.ftdichip.com/Drivers/CDM/CDM21228_Setup.zip
    Thanos
  9. SOUTHROD
    39Coins
    4DOF
    Ive downloaded all the update firmware and drivers and reset the AmC controller and all works great,but Sim Racing Studio is not recognising the controller,i.e the icon Check on the SRS bottom right is not a green tick do I need to do something else for it to be recognised,SRS seems like a great software but it need some dummy proof instructions on how to connect it and use it.
  10. Thanos
    2,908Coins
    Hi, SRS pings all connected devices to identify where they are connected. But the way they do that is by toggling the DTR line causing usually the target device to reset. To avoid having the AMC controller resetting, you need to cut the RESET_EN trace on the board. See this video how to locate and cut that trace with a exacto knife:
    After that, there are lots of detailed guides to follow to start with SRS...
    Quick start guide for AMC-AASD15A controller setup:
    https://bit.ly/3lX6ON5
    http://www.pt-actuator.com/uploads/soft/201020/PTActuators-quickstartguide.pdf
    Tuning guide:
    https://www.simracingstudio.com/forum/motion-profiles/srs-2-0-motion-tuning-guide
    And if anything is not covered, you can always ask in Discord:
    https://discord.gg/bx4PxYR
  11. SOUTHROD
    39Coins
    4DOF
    Thankyou so much I was tearing what little hair I have out wondering what I had done wrong.
    Shane.
