value1
Codemasters Dirt 4 Plugin 2.0.1.5
SimTools plugin for Codemasters Dirt 4
  1. noorbeast
    152,259Coins
    +11,066 / 56 / -2
    Codemaster game patch paths differ, depending on Windows being 32 or 64bit: https://www.xsimulator.net/communit...-32-bit-install-path-for-motion-patching.260/
    ProjectCars requires in game configuration of settings: https://www.xsimulator.net/community/faq/projectcars.188/
    These and other tips and fixes for different games can be found in the FAQs: https://www.xsimulator.net/community/faq/game-tips-and-fixes.19/category
  2. EleaSkipper
    EleaSkipper New Member
    - 45Coins
    for Dirt 4 , I believe the Game already patched for dirt 4 folder and still no feed back , by the way I'm using Dirt 4 version 1.0 and the plugin for v 2.0, is that a problem? and if it is , is there is Dirt 4 v1.0 plugin?... thank u
    152,259Coins
    +11,066 / 56 / -2
    The game plugin version is independent of game version, so is not the issue.
    Please post pictures of all settings, including the Tuning Center while Dirt4 is running, to check for game data.
  4. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    2DOF, DC motor, SimforceGT
    after doing everything you say you went to my my game documents to edit the hardware_settings_config file in the folder.
    C: \ Users \ moaal \ Documents \ My Games \ DiRT Rally 2.0 \ hardwaresettings
    You have to edit these lines by the port that the plugin gives you and the IP that you have on your machine.
    <dbox enabled = "true" />
    <udp enabled = "true" ip = "127.0.0.1" port = "20777" delay = "1" extradata = "3" />
    this works on dirt 2/3/4 / rally less on dirt 5
  5. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    you will always have to use the latest plugin whatever the game is, no matter what update the game is
  6. EleaSkipper
    - 45Coins
    hello guys , Dirt 4 start giving feedback i think ,but but so small amount witch is barely make the stepper move but i cant see it moving because I u can see in the image the feedback amount so small ... [​IMG]
  7. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    you would have to put a video
    152,259Coins
    +11,066 / 56 / -2
    Yes there is game data, but your TC values are too high.
    You can Capture Max Min, drive around a lap and don't hit anything, save and then tweak the values from there.
    See the motion profile tuning tips in the FAQs: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  9. EleaSkipper
    - 45Coins
    Okay , thats helped a lot , Dirt 4 now work probably ... but importantly DiRT Rally 2 0 still no feedback , I patched it and edited thehardware settingsconfig.xml file like dirt 4, but still no feed back at all in tuning center ...
