FlyPT Mover 3.5.3
  1. kparkin
    kparkin Member
    United Kingdom
    236Coins
    4DOF
    Happy to be of help. I'm sure that it will be fixed in the next release.
  2. Avee
    Avee Virtual Pilot
    1,167Coins
    I am trying to use your UDP source, but I think I just don't get the concept.
    What I did thus far:
    -created a mechanical device to measure pose with potentiometers
    -programmed an arduino to send out the pose over the com port as bytewise float values (6x 4 bytes)
    -running bridges to create a serial to UDP server on 127.0.0.1:55556
    -Configure a custom UDP source (address 127.0.0.1:55556) with 6 4-byte float values, with offsets of 0,4,8 etc. Transition detection just by having enough data.
    Now when I press connect on my UDP source, it turns yellow, stays yellow, and all values stay at 0.
    What could be the problem?
  3. pmvcda
    15,485Coins
    Use the IP of the PC with Mover in the Arduino.
    127.0.0.1 is the address of the device, so you are sending from the Arduino to the Arduino.
  4. Avee
    Avee Virtual Pilot
    1,167Coins
    The Arduino is connected via serial COM50 to the PC. The Serial to UDP bridge software as well as PTMover are running on the PC. Using the external address of the PC gives the same result.
  5. pmvcda
    15,485Coins
  6. Avee
    Avee Virtual Pilot
    1,167Coins
    Yes I have been using that. I think there is something that I don't understand about the topology. When I try to connect as receiver only, it will try to open a socket on port 55556 itself, which doesn't work as the bridge is already using that. It will connect as a sender to 127.0.0.1:55556, but then I don't get any output from the bridge.
    I am just sending raw bytes over the com port, no protocol or handshake. Just a stream of pose data. Not sure whether that is valid to forward that over UDP.
  7. Trigen
    Trigen Active Member
    2,890Coins
    Version 3.4.2
    Im having some issues with the Condor 2 profile. I have saved it many times but it always defaults to the top on my directs.
    It may be due to the fact that they both just show as Condor 2 (udp) But the bottom is ground. Since you only get ground data on this one it. Not a big deal to click on these two but i always forget so it would be nice to have it working.
  8. itonylee
    itonylee New Member
    Bandung, Indonesia
    246Coins
    I built my 6DOF few years back and use the a proprietary commercial control board to control my linear servo.
    Due to data format issues, I end up wrote my own interface program to convert/translate the game telemetry data into platform motion and send to control board through serial port.
    Yesterday I saw Flypt-mover with many exciting features and I decide to give it a try.
    I got stuck again with data format issue. My board is expect to read 32bit (4 bytes) single float data for each sway/surge/heave/pitch/roll/yaw. therefore, in my own program, if I need to output sway (range: -300 ~ 300) to my board. I need to do
    byte[] swayBytes = BitConverter.GetBytes(float sway)
    and send that swayBytes to my board together with other data through serial port.
    It seems to me that Flypt-mover only support output in unsigned integer. I wonder if there any way I can make output to 32bit single float data so my board can read the data.
    Tony
  9. pmvcda
    15,485Coins
    Right now, I'm outputing the pose in double. But I can add float.
    I can also add the option to output pose in measures here:
    This avoids the use of the rig module, outputing the sum of the selected poses.
    Will try to add it in the next release. Soon.
  10. itonylee
    itonylee New Member
    Bandung, Indonesia
    246Coins
    Wow, thanks so much for quick reply. This will definitely work for my situation.
  11. itonylee
    itonylee New Member
    Bandung, Indonesia
    246Coins
    I also have this strange situation here while experimenting control each actuator axis directly.
    In the debug of serial output panel, I was able to get the reading from <PPoseHeave> but not from each <Axis #a>.
    Please see my screenshot below, Thanks
  12. itonylee
    itonylee New Member
    Bandung, Indonesia
    246Coins
    I just realize that I do need to connect to serial port in order to have output debug for each axis
  13. Lebois
    Math teacher
    2,566Coins
    @pmvcda Would it be possible to add the support for joysticks to setup the shortcuts : Capture.JPG
    That way we could control the rig with a simple button box :)
  14. pmvcda
    15,485Coins
    It's there already.
    Click the field to put it yellow, and press the desired joystick button instead of keyboard key
  15. Lebois
    Math teacher
    2,566Coins
    @pmvcda Thanks for your reply ! I tried again : in fact, we can't use the simucube buttons, but I confirm we can use buttons from an arduino button box...
    If you have time to check why it doesn't work with the simucube...
  16. Historiker
    9,208Coins
    I do not have any buttons on my Simcube (OSW) set up but I do have eight other controllers on my motion rig. I tested each of them and they work with Mover.
    Thrustmaster Warthog (No Target, test both stick and throttle)
    8 speed shifter (DIY Thingiverse)
    Thrustmaster Cougar Throttle
    Thrustmaster Cougar MFD (Three of them)
    Fanatec BMW Wheel (Teensy LC Mod)
    Could be something is odd about the SimuCube controller? I should plug some buttons into mine one of these days.
  17. Lebois
    Math teacher
    2,566Coins
    Yeah I guess it comes from the simucube but that's odd...
    bad thing is that all the dashboard is plugged on the simucube...
  18. Historiker
    9,208Coins
    Are all the buttons working as DX input otherwise?
  19. Lebois
    Math teacher
    2,566Coins
    just checked : no :/
    windows shows only about 16 buttons, that aren't mine...
  20. Historiker
    9,208Coins
    Lets take this to PM, as it is not Mover related ;)
