Bug SimTools .NET Framework Unhandled Exception
Discussion in 'SimTools DIY Version' started by amahvan, Apr 29, 2021.
  1. amahvan
    amahvan New Member
    8Coins
    Hey all, I have been happily and comfortably using SimTools for several months now with no issues at all. Today I decided to download the Xplane11 plugin and give it a try.
    I ran the SimTools PluginUpdater, it updated successfully.
    Then I opened Game Manager and got a .NET Framework error. "Object reference not set to an instance of an object." aaaaannnd it was broken.
    Details:
    Code:
    System.ArgumentException: The path is not of a legal form.
       at System.IO.Path.LegacyNormalizePath(String path, Boolean fullCheck, Int32 maxPathLength, Boolean expandShortPaths)
       at System.IO.Path.NormalizePath(String path, Boolean fullCheck, Int32 maxPathLength, Boolean expandShortPaths)
       at System.IO.Path.GetFullPathInternal(String path)
       at System.IO.DirectoryInfo.Init(String path, Boolean checkHost)
       at System.IO.DirectoryInfo..ctor(String path)
       at SimTools_GameManager.frm_GameManager.If_StartWithWindows_Checked()
       at SimTools_GameManager.frm_GameManager.frmMain_Load(Object sender, EventArgs e)
       at System.EventHandler.Invoke(Object sender, EventArgs e)
       at System.Windows.Forms.Form.OnLoad(EventArgs e)
       at System.Windows.Forms.Form.OnCreateControl()
       at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
       at System.Windows.Forms.Control.CreateControl()
       at System.Windows.Forms.Control.WmShowWindow(Message& m)
       at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
       at System.Windows.Forms.Form.WmShowWindow(Message& m)
       at System.Windows.Forms.Form.WndProc(Message& m)
       at SimTools_GameManager.frm_GameManager.WndProc(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    mscorlib
        Assembly Version: 4.0.0.0
        Win32 Version: 4.8.4341.0 built by: NET48REL1LAST_C
        Assembly Version: 0.2.5.1
        Win32 Version: 0.2.5.1
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameManager.exe
    fZMkmPzPHuCqHgqhDnkBggdEJqAS
        Assembly Version: 0.0.0.0
    Microsoft.VisualBasic
        Assembly Version: 10.0.0.0
        Win32 Version: 14.8.4084.0 built by: NET48REL1
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
        Win32 Version: 4.8.4300.0 built by: NET48REL1LAST_C
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
        Win32 Version: 4.8.4084.0 built by: NET48REL1
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
        Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Runtime.Remoting
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    enabled.
    For example:
    <configuration>
    </configuration>
    I have already attempted:
    • Uninstalling and Reinstalling SimTools from scratch
    • NET Framework Repair Tool (no solution)
    • Administrator CMD Scan (no solution)
    • CMD DISM (no solution)
    • Windows Features > Disable all NET Framework (no solution)
    • Windows Features > Enable all NET Framework (no solution)
    • Reinstalling NET 4 (no solution - "Your operating system is already running this)
    I'm running out of ideas here.
    153,986Coins
    +11,162 / 57 / -2
    Hopefully @yobuddy has some suggestions.
  3. amahvan
    amahvan New Member
    8Coins
    I ran out of potential fixes, and resorted to a full factory reset of my virtual machine (I'm playing on Shadow.tech), and now that I've reinstalled everything, SimTools won't let me activate because my "activation key has been used too many times" . It never ends.
  4. yobuddy
    51,552Coins
    You can send an email here buddy, and we will get it sorted.
    https://simtools.us/contact-us/
    But if we install the xplane plugin and a problem happens, we could try to remove it.
    I realize I'm a bit late to the party, but if we goto "C:\Users\(your user folder)\AppData\Local\SimTools\GamePlugins" we can simply delete the game dll and then restart simtools to see if we are up and running again.
    Take care,
  5. amahvan
    amahvan New Member
    8Coins
    Just shot an email over a few mins ago--I appreciate it big time bro. Trying the entire process from scratch again with a fresh start, and hoping I can get it working properly.
    I tried this--the issue was a .NET Framework exception, and even after deleting all dll files, I could not get SimTools to launch at all without throwing the exception. It was also the only program affected, so I thought a complete uninstall and deletion of all files would fix it, but on reinstall the same problem occurred.
  6. miaziol
    miaziol Member
    Poland
    - 60Coins
    i have similar problem, on my wife laptop work very well, but on my gaming computer I can't start it. I try reinstall net framework. tool for repair find nothing. its a log:
    See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text **************
    System.ArgumentException: The path is not of a legal form. at System.IO.Path.LegacyNormalizePath(String path, Boolean fullCheck, Int32 maxPathLength, Boolean expandShortPaths) at System.IO.Path.NormalizePath(String path, Boolean fullCheck, Int32 maxPathLength, Boolean expandShortPaths) at System.IO.Path.GetFullPathInternal(String path) at System.IO.DirectoryInfo.Init(String path, Boolean checkHost) at System.IO.DirectoryInfo..ctor(String path) at SimTools_GameEngine.frm_GameEngine.StartWithWindows_Checked() at SimTools_GameEngine.frm_GameEngine.frmMain_Load(Object sender, EventArgs e) at System.EventHandler.Invoke(Object sender, EventArgs e) at System.Windows.Forms.Form.OnLoad(EventArgs e) at System.Windows.Forms.Form.OnCreateControl() at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.WmShowWindow(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.Form.WmShowWindow(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version:
    4.0.0.0
    Win32 Version: 4.8.4400.0 built by: NET48REL1LAST_C CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll ---------------------------------------- SimTools_GameEngine Assembly Version:
    0.2.5.1
    Win32 Version:
    0.2.5.1
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameEngine.exe ---------------------------------------- XuDYjHvzySWkLCvzNJOypnienfi Assembly Version:
    0.0.0.0
    Win32 Version:
    0.2.5.1
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameEngine.exe ---------------------------------------- Microsoft.VisualBasic Assembly Version:
    10.0.0.0
    Win32 Version: 14.8.4084.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll ---------------------------------------- System Assembly Version:
    4.0.0.0
    Win32 Version: 4.8.4360.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Core Assembly Version:
    4.0.0.0
    Win32 Version: 4.8.4390.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll ---------------------------------------- System.Windows.Forms Assembly Version:
    4.0.0.0
    Win32 Version: 4.8.4400.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version:
    4.0.0.0
    Win32 Version: 4.8.4390.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.Configuration Assembly Version:
    4.0.0.0
    Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Xml Assembly Version:
    4.0.0.0
    Win32 Version: 4.8.4084.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System.Runtime.Remoting Assembly Version:
    4.0.0.0
    Win32 Version: 4.8.4084.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll ---------------------------------------- Log Assembly Version:
    1.0.0.0
    Win32 Version:
    1.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/Log.DLL ---------------------------------------- System.Windows.Forms.resources Assembly Version:
    4.0.0.0
    Win32 Version: 4.8.4084.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_pl_b77a5c561934e089/System.Windows.Forms.resources.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
  7. yobuddy
    51,552Coins
    Seems to be having a problem with a path?
    The path is not of a legal form...
    How are you getting this error buddy?
    At launch, install?
  8. miaziol
    miaziol Member
    Poland
    - 60Coins
    at launch when I hit ignore program start, but I can't make anything.
  9. najmi
    najmi New Member
    64Coins
    H
    hi guys..any solution? Since im also stuck with this issue during launch the software..
  10. HASAN1453
    HASAN1453 Member
    Vr arcade owner
    VANCOUVER
    424Coins
    2DOF, 3DOF, Motion platform
    I am having the same problem @yobuddy do we have any solution?
  11. yobuddy
    51,552Coins
    All I can think is it may be where SimTools was installed?
    And the resulting path is to long?
    May I ask where you have it installed?
    Chat soon
  12. donottellmywife
    donottellmywife Member Gold Contributor
    Something something tech related
    424Coins
    I have a brand new installation and the moment I add the first additional new game beyond the default "Live for Speed" I get the same error messages. Sim Tools is installed the default directory it suggests which is a fairly short path. Clearing out the new game DLL from the app folder in the user profile and just having "Live for Speed" fixes it.
    I tried different games, each with the same result. Using Simtools 0.2.6 .. basic W11 box. Feel free to DM me (we are in the same timezone).
  13. yobuddy
    51,552Coins
    Are you using v2 plugins with SimTools v2 and V3 plugin with V3?
    Just wondering is all.
  14. donottellmywife
    424Coins
  15. donottellmywife
    424Coins
    Let me try something out quickly. I think I have a hunch of what is going and it is purely on how you make content available and how the messaging around it is written that is confusing.
    "Please note that SimTools 2 plugins will only work with SimTools 2 and SimTools 3 plugins will only work with SimTools 3."
    Gimme a hour or two and I'll get back to you with some thoughts / recommendations if my suspicions are right.
    EDIT: Quickly bought the gold contributor package to check and verify and my suspicions are right. The above reported error messages are related to people installing the 3.0 sim tools game packages which are freely available from Downloads & Links – SimTools. The plug-ins you can download for free from Plugin Library (simtools.us) are 3.0 links but that isn't clearly indicated anywhere on the page. 2.0 plug-ins are downloaded from here but they require you to get either coins or a contributor package. It for sure confused me and I actually am directly involved in writing tech content so let alone we are dealing with people who aren't well versed in this.
    Before this forum gets a ton more of these posts my recommendations are:
    Change the language on Downloads & Links – SimTools and make it very clear on the distinction that you need to go to a different page for downloading plug-ins for 2.0. Probably should link to that.
    Change language on the top banner on the same page to specifically say 3.0 plugins instead of plugins
    On Plugin Library (simtools.us) specifically call out that these plug-ins are for the 3.0 version and again link to the 2.0 repository for those plugins. (it would be nice if the software would detect you try to install a 3.0 plugin on a 2.0 software but I understand that might not be easy).
    Hope this helps.
  16. yobuddy
    51,552Coins
    This is being worked on, but keeps getting pushed back as other things need fixing.
    But will get done for sure.
  17. sardiusxu
    sardiusxu New Member
    143Coins
    4DOF
    I have encountered a similar problem, with the code being
    Code:
    System.NullReferenceException: Object reference not set to an instance of an object.
    at SimTools.Cls_Reg._GetProcessorId()
    at SimTools.Cls_Reg._GetUnique()
    at SimTools.Cls_Reg._CheckLicense(String Key, String ID)
    at SimTools.Frm_SimTools.Registration_ClickedButton(Button_Type ButtonClicked)
    at MyRegBox.MyRegBox.Pic_Activate_MouseClick(Object sender, MouseEventArgs e)
    at System.Windows.Forms.Control.OnMouseClick(MouseEventArgs e)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    mscorlib
    Win32 Version: 4.8.9037.0 built by: NET481REL1
    SimTools
    Assembly Version: 3.0.0.0
    Win32 Version: 3.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/SimTools.exe
    FzLevFHZrVELcuOcYafQasTUIzZeA
    System
    System.Drawing
    Game_PluginAPI_v3
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/Game_PluginAPI_v3.DLL
    Axis_PluginAPI_v3
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/Axis_PluginAPI_v3.DLL
    Interface_PluginAPI_v3
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/Interface_PluginAPI_v3.DLL
    Win32 Version: 14.8.9037.0 built by: NET481REL1
    MyVibeButtons
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyVibeButtons.DLL
    MyTuningButtons
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTuningButtons.DLL
    MyCrashButtons
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyCrashButtons.DLL
    System.Xml
    Accessibility
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    Tool_AddonAPI_v3
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/Tool_AddonAPI_v3.DLL
    Default_AxisPlugin
    CodeBase: file:///C:/Users/gnefu/AppData/Local/SimTools3/AxisPlugins/Default_AxisPlugin.dll
    Default_InterfacePlugin
    CodeBase: file:///C:/Users/gnefu/AppData/Local/SimTools3/InterfacePlugins/Default_InterfacePlugin.dll
    VirtualOutputAPI_v3
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/VirtualOutputAPI_v3.DLL
    Default_VirtualPlugin
    CodeBase: file:///C:/Users/gnefu/AppData/Local/SimTools3/VirtualPlugins/Default_VirtualPlugin.dll
    GameDash_PluginAPI_v3
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/GameDash_PluginAPI_v3.DLL
    Default_GameDashPlugin
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Users/gnefu/AppData/Local/SimTools3/Dash/Plugins/Default_GameDashPlugin.dll
    CSCore
    Assembly Version: 1.2.1.2
    Win32 Version:
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/CSCore.DLL
    MyDropBox
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyDropBox.DLL
    MyTextBox
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTextBox.DLL
    MyTextBox_MinMax
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTextBox_MinMax.DLL
    MyCheckBox
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyCheckBox.DLL
    MyOneClick
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyOneClick.DLL
    MyPicMenu
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyPicMenu.DLL
    MyScrollBar
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyScrollBar.DLL
    MyLoadButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyLoadButton.DLL
    MyButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyButton.DLL
    MyDashControl
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyDashControl.DLL
    MyExport
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyExport.DLL
    MyRepoInstall
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyRepoInstall.DLL
    MySaveButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MySaveButton.DLL
    MyProfileComboBox
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyProfileComboBox.DLL
    MyTuningScrollBar
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTuningScrollBar.DLL
    MyBannerStopButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyBannerStopButton.DLL
    MyRadioButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyRadioButton.DLL
    MyNewName
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyNewName.DLL
    MyPatchingNotes
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyPatchingNotes.DLL
    MyUpDown
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyUpDown.DLL
    MyNotifyMarker
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyNotifyMarker.DLL
    MyParkingLocation
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyParkingLocation.DLL
    MyOnOffSlider
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyOnOffSlider.DLL
    MyAxisLimiting
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyAxisLimiting.DLL
    MyTopMenu
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTopMenu.DLL
    MyRegBox
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyRegBox.DLL
    MyRepoButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyRepoButton.DLL
    MyMessageBox
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyMessageBox.DLL
    MyFolderBrowser
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyFolderBrowser.DLL
    MyMainMenu
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyMainMenu.DLL
    MyDatePicker
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyDatePicker.DLL
    MyTextPrompt
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTextPrompt.DLL
    mscorlib.resources
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_zh-Hans_b77a5c561934e089/mscorlib.resources.dll
    System.Core
    System.IO.Compression.FileSystem
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IO.Compression.FileSystem/v4.0_4.0.0.0__b77a5c561934e089/System.IO.Compression.FileSystem.dll
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IO.Compression/v4.0_4.0.0.0__b77a5c561934e089/System.IO.Compression.dll
    System.Drawing.resources
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing.resources/v4.0_4.0.0.0_zh-Hans_b03f5f7f11d50a3a/System.Drawing.resources.dll
    Network_GameDashPlugin
    CodeBase: file:///C:/Users/gnefu/AppData/Local/SimTools3/Dash/Plugins/Network_GameDashPlugin.dll
    Serial_GameDashPlugin
    CodeBase: file:///C:/Users/gnefu/AppData/Local/SimTools3/Dash/Plugins/Serial_GameDashPlugin.dll
    Virtual_GameDashPlugin
    CodeBase: file:///C:/Users/gnefu/AppData/Local/SimTools3/Dash/Plugins/Virtual_GameDashPlugin.dll
    System.Management
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    enabled.
    For example:
    <configuration>
    </configuration>
  18. yobuddy
    51,552Coins
    I'm afraid I don't have anything to go on here.
    Any idea what the last thing you were doing before you got this?
    If not, I would simply re-install buddy.
    Take care!
  19. RoryP
    RoryP New Member
    16Coins
    Iam having the same issue but only with iracing. It has worked for years but sometimes before it came up at first start up but then i shut down down iracing and simtools and started up again and then it always worked. But now it always comes up.
    Does anyone have any ideas?
  20. jonston5
    jonston5 New Member Gold Contributor
    Australia
    - 281Coins
    Hi Rory did you find a solution? My iracing is playing up too.
