Start a project, 2dof or 4dof why?
Discussion in 'DIY Motion Simulator Projects' started by marco cristopulos, May 3, 2021.
  1. marco cristopulos
    marco cristopulos New Member
    139Coins
    I see how connect 2dof electric blue print, the 4dof is same?
    153,770Coins
    +11,149 / 57 / -2
  3. marco cristopulos
    139Coins
    I am starting with the motors, I need help with the connections and how to isolate their mass since it is different from the ones I have seen, I need to know what the cables are and where to connect them.
    I disassembled the black part, but it cannot be put back together, luckily I have two
    153,770Coins
    +11,149 / 57 / -2
  5. marco cristopulos
    139Coins
    Yo reviso same that link and dont come to back armed agai i think are different, have only 2 cablw inside
  6. marco cristopulos
    139Coins
    Check pls
  7. C1500
    C1500 Active Member
    1,119Coins
    AC motor, 6DOF
    Hi marco
    I think the yellow and green wire are for the motor.
    The other wires (red, white and black) are possibly for position detection as a whiper to switch the motor oposit direction.
    You will not need these wires.
    Do you have a multimeter?
    Measure the resistance between case of the motor and the yellow and green line.
    If there is no connection, you can put ground/shild on the case.
    cheers
    Peer
