6DOF Prototype using small dc motors
Discussion in 'DIY Motion Simulator Projects' started by Gustavo Massaneiro, Jun 3, 2018.
  1. Gustavo Massaneiro
    Gustavo Massaneiro New Member
    Brazil
    80Coins
    2DOF, 3DOF, DC motor, Arduino, 4DOF, 6DOF
    Hello Folks,
    I'm building a prototype of 6DOF simulator using dc motors and rotary encoder instead of regular pots/hall effect sensors. I’m using the SMC3 software as a reference, and building my own software based on the SMC3, but just for 2 motors and 2 rotary encoders, also using freeRTOS with tasks and a nodeJS server that receives the SimTools UDP packets and send through the serial port to Arduino Uno.
    My Setup:
    · 6x Small DC motors (3-6v)
    · 6x Rotary Encoders (KY-040)
    · 3x L298N boards (H-bridge)
    · 12x Mini kossel spherical joints
    · 3x Arduino Uno
    I’m planning to use just one pc to handle everything, pc settings:
    · Intel i7 7700K @ 4.5 ghz
    · AsRock z270 PRO4
    · 8gb Corsair Vengeance DDR4 @ 3000 mhz
    · Gigabyte GTX 1070 8gb
    · 2x 128gb SSD Samsung Pro 840 @ Raid0
    · Logitech G27 Gaming Wheel
    · Stockcar Cockpit for G27
    I’ve updated the SMC3 software to use the rotary encoder instead of the pots.
    Here is the info regarding the rotary encoder: http://henrysbench.capnfatz.com/hen...es-ky-040-arduino-rotary-encoder-user-manual/
    The Rotary Encoder has a total of 30 rotations, it means 30 rotations = 360 degrees
    1024/30 = 34.13 per rotation on a total range of 0 – 1020 for 360 degrees
    Limiting the rotary encoder rotation to 180 degrees: 1024/15 = 68.26 per rotation on total range of 0 – 1020 for 180 degrees.
    The feedback seems to be working fine with the rotary encoder, but it seems that the dc motor gearbox has a lot of slack, something is wrong:
    Now testing the Axis1a using the SimTools Output Testing:
    I would like to have your opinion about the feedback using the rotary encoder, what is wrong? The code is attached.
    Also, I need to use something to get the current position of the rotary encoder after power on/down, some type of calibration based on the min/max angles, maybe using 2 sensors for min/max angle to calibrate the rotary encoder and go to center position.
    Code used for the rotary encoder:
    initEncoder(MOTORA_CLK, MOTORA_DT);
    //Feedback1 = analogRead(FeedbackPin1);
    Feedback1 = encoder.currentValue;
  2. Gadget999
    12,144Coins
    What type of motors do you use ? Do they have a gearbox ?
  3. SeatTime
    Yes, he has a gearbox on his small motors (see his first picture - gearbox in yellow). I'm not surprised that they have some slack :). You could use limit switches and some code for initial calibration.
  4. Gustavo Massaneiro
    Brazil
    80Coins
  5. Gustavo Massaneiro
    Brazil
    80Coins
    My rotary encoder direction was inverted, it was causing initial failure of the software with invalid feedback values.. And I thought the problem was the L298N board :(
    The range of SimTools axis is just 100-923, why? Shouldn't be 0-1024?
    I'm planning to use Optic Sensors TCRT5000 as limit switches, I will test the min range of them and check if they work as expected.
    First test of the motor after some regulations:
  6. Gustavo Massaneiro
    Brazil
    80Coins
    I bought 2 monster motor shields, lets see if I have lucky with them.
    The first board has poor soldering on the chips and a short circuit ping soldering on one of the chips. Also I can't even read the chips info.
    The second board looks better, I can read the chips info and the soldering is better.
    I will test the second board and re-solder some pins of the first board.
  7. marco cristopulos
    marco cristopulos New Member
    139Coins
    Can u help with connection h bridge l298n to arduino, i am complete noob and try to find how a lot time and cant find
