Showroom Simple seat mover
Discussion in 'DIY Motion Simulator Projects' started by Mike Melga, Feb 15, 2021.
  1. Abram Manoge
    Abram Manoge Member
    Web developer
    South Africa
    319Coins
    What motors are those and how many watts?
  2. André6969
    André6969 New Member
    22Coins
  3. Halloween2go
    Halloween2go Active Member Gold Contributor
    1,395Coins
    Jeeze.. I have not even considered painting my frame yet.. (it's been 8 months). I'm just having fun racing it! I probably will swap the seat for an aluminum one like the Kirkey 55 (which means I will have to rebalance the rig for optomum performance (*AGAIN).. but right now, the 3dof rig is awesome.. So not trying to stray you away from your baby, but Mine works just fine.. and I have a ton of videos on it on my YT channel DMAX
  4. Mike Melga
    Mike Melga Member
    IT
    663Coins
    Hi.
    I will post pictures this weekend of the current state. It's almost done :)
    I've been testing and playing with Simtools but I have one problem: it seems that the pitch axis (the one that controls acceleration and braking) is inverted. Did I connect something wrong in the Arduino/SMC3?
  5. Halloween2go
    1,395Coins
  6. Mike Melga
    Mike Melga Member
    IT
    663Coins
    Halloween2go,
    Thanks.
    Just out of curiosity...why did the axis needed to be inverted?
    Did I connect something wrong in the motor drivers?
    What should I invert to prevent needing to invert in the software?
    153,986Coins
    +11,162 / 57 / -2
    The DIR boxes being checked orange or not determine which way each axis moves, do if the pitch axis is inverted you can fix it with the DIR settings, this is what SimTools expects: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
    For race sims be mindful of the Axis Allocation totals: https://www.xsimulator.net/community/faq/axis-assignment-percentage-totals.120/
    Once you get the rig moving seeing the tuning tips here: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  8. kalbasator
    kalbasator Active Member
    Kazahstan, Almaty
    170Coins
    3DOF, DC motor, Arduino, Motion platform, 4DOF
    Hello, how are you! I noticed you have installed a conventional steering wheel.
    I'm wondering - what kind of motor is installed there and how is it controlled?
  9. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    2DOF, DC motor, SimforceGT
    Hello friend, what would those plates be for? thumbnail_IMG_20210405_090348.jpg
  10. kalbasator
    Kazahstan, Almaty
    170Coins
    Hello! Based on the description on the first page, these are Cytron MD13S drivers for motors.
