question
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Hongdao0311, May 5, 2021.
Tags:
  1. Hongdao0311
    Hongdao0311 New Member
    66Coins
    Hi can you help me I just finished 2dof motion in simtool software I used rolls and pitch when testing it worked normally but in LFS game it didn't work as tested so what should I do hope you help me thank
    153,824Coins
    +11,151 / 57 / -2
  3. Hongdao0311
    66Coins
    ok my friend will try, but let me ask more before i used monster motor shield circuit now i switch to bts7960 circuit but the software as well as plugin i still leave unchanged, is there any problem, or have to change
    153,824Coins
    +11,151 / 57 / -2
  5. Hongdao0311
    66Coins
    Thank you, I made it, ACC, Rally 2.0 game ran well but why game f1 2020..dirt3-4 why doesn't it work?
    153,824Coins
    +11,151 / 57 / -2
  7. Hongdao0311
    66Coins
    hello friend I did as you instructed but it still doesn't work .f1 2020 too ... so what should i do, i don't know what's wrong
    153,824Coins
    +11,151 / 57 / -2
    Please post pictures of ALL of your settings, including the Tuning Center with the game running.
  9. Hongdao0311
    66Coins
    Here it is, sir
    153,824Coins
    +11,151 / 57 / -2
    Has the game patched correctly, as there is a message to first complete a race?
    The Tuning Center has zero set for all settings. That could be because the game is not patched, but if the game is patched higher vales will be needed, you can capture Max/Min values, see the tuning tips here: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    I presume Output Testing works correctly, is that correct?
  11. Hongdao0311
    66Coins
    I don't know what racing mode I tried to finish 2-3 rounds but I patched it, it still says so
    153,824Coins
    +11,151 / 57 / -2
    Does Output Testing works correctly?
  13. Hongdao0311
    66Coins
    I tried it works very well with the surge and sway that I have installed but in game it doesn't work
