First steps
Discussion in 'Forum and Website' started by Kenshiro27, Apr 30, 2021.
  1. noorbeast
    153,824Coins
    +11,150 / 57 / -2
    Hit the Details button and then copy and paste the full error message.
  2. Kenshiro27
    Kenshiro27 Active Member
    252Coins
    2DOF, 3DOF, Arduino
    here is the message in full. I have already tried to update the framework 4.8 and it was already up to date
    System.IO.FileNotFoundException: Could not load file or assembly 'Game_PluginAPI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. Le fichier spécifié est introuvable.
    File name: 'Game_PluginAPI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null'
    at SimTools_GameManager.frm_GameManager.LoadGameList()
    at SimTools_GameManager.frm_GameManager.frmMain_Load(Object sender, EventArgs e)
    at System.EventHandler.Invoke(Object sender, EventArgs e)
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    at System.Windows.Forms.ContainerControl.WndProc(Message& m)
    at System.Windows.Forms.Form.WmShowWindow(Message& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    at SimTools_GameManager.frm_GameManager.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    AVT : la journalisation de liaison d'assembly est désactivée.
    Pour activer la journalisation des échecs de liaison d'assembly, attribuez la valeur 1 à la valeur de Registre [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD).
    Remarque : une certaine perte de performance est associée à l'enregistrement dans le journal des échecs de liaison d'assembly.
    Pour désactiver cette fonctionnalité, supprimez la valeur de Registre [HKLM\Software\Microsoft\Fusion!EnableLog].
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4300.0 built by: NET48REL1LAST_C
    Assembly Version: 0.2.5.1
    Win32 Version: 0.2.5.1
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameManager.exe
    fZMkmPzPHuCqHgqhDnkBggdEJqAS
    Assembly Version: 0.0.0.0
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    Win32 Version: 4.8.4270.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    Win32 Version: 4.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Core
    Win32 Version: 4.8.4320.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    System.Xml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    Accessibility
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    enabled.
    For example:
    <configuration>
    </configuration>
    153,824Coins
    +11,150 / 57 / -2
  4. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    thank you for your reply, i'm trying the suggestions you gave me
  5. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    I managed to get simtools to work after a lot of hassle. I uninstalled framework, simtools, changed configurations of the pc to administrator and oh miracle: it works. I unfortunately cannot tell you precisely what made it work Now, if one parameter or set makes it work.
    In any case, I did my first laps in homemade simracing and it's really great
    A big big thank you !!!
    Without you and this site I would not have made ithug:
  6. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    I advanced in the aesthetics of my simulator by installing the sides, it looks more like the starting idea
  7. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    My personal touch in thanks and tribute (I had thought of an Australian flag but I would have made people jealous;))
  8. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    What could be better than a DIY steering wheel to accompany a DIY simulator
  9. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    I'll show you the final version of my project
  10. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    And the small crankset that I bought myself used but which works perfectly, and with the loadcell it adds to the immersion
  11. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    I still have a question regarding the settings. I use EXACTLY the same settings with asseto corsa as with asseto corsa competizione and the rendering is totally different. In the first step of sensation at the level of SWAY and SURGE, the rest is OK.And in competizione everything works fine.Rule or plugin problem?
    153,824Coins
    +11,150 / 57 / -2
    Likely a motion profile settings issue, as Assetto Corsa and Asseto Corsa competizione use 2 totally different game engines.
  13. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    Hello Noorbeast,
    could you define me what is: motion profile settings
    In simtools or in the game itself?
    153,824Coins
    +11,150 / 57 / -2
    Grab a copy of the SimTools manual, as that is your best guide to understanding how SimTools works: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    You will find additional member handy hints in the FAQs: https://www.xsimulator.net/community/faq/simtools-settings-tips-and-tricks.18/category
    In particular have a look at the tips on how to go about setting up and refining a motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  15. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    Thank you for your reply
  16. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    I made a part to adapt an adjustable damper on my pedal for the brake pedal as well as the replacement of the spring on the accelerator pedal, all in order to always add a little more realism to my simulator
  17. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    I had also started the realization of a handbrake but it could not have worked when "all or nothing" but I found one in 16bit for barely 40€ and aesthetically much nicer
  18. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    Hello,here is the French version of the simtools notice,it is not perfect because using a translation software. It took me a lot of time but so I could have a better understanding of the software.As well as all the members of xsimulator francophone who like me does not master English.Thank you to see place in the right place this file so that everyone the world can enjoy it
    153,824Coins
    +11,150 / 57 / -2
    Thanks for that, I have added it to the FAQ manual section, with credit to yourself: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
  20. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    Thank you very much, I found here and thanks to you a lot of help to realize my simulator project, so it was normal for me to contribute in turn
