GameVibe not working in a new PC
Discussion in 'SimTools Plugins' started by Sento Siete, May 23, 2021.
  1. Sento Siete
    Sento Siete Member Gold Contributor
    Valencia (Spain)
    304Coins
    2DOF, SCN5
    I've changed my PC and, after a little problem with the rFactor patching, motion works perfect; but can get working the Game Vibe and it worked before with all the sims.
    I've done all the configuration process, and the test works right, getting vibration from all the four shakers, but when I get into any game (rF2, AMS 2, AC, ACC), can't get any vibration.
    This is the configuration for AMS2, but the other games are similar:
    No feedback error when runing the sims. What else can I try?
  2. Sento Siete
    Valencia (Spain)
    304Coins
    2DOF, SCN5
    If I open the Game Vibe and the Tuning Center windows, sometimes rF2 works (other times don't), but if I try to change the sim in the Tuning Center, I get this error:
    153,722Coins
    Can you please hit the Details button on the error message then copy and paste the full error, that way @yobuddy can have a look and give some advice.
  4. yobuddy
    51,523Coins
    Once you run the game once, the inputs should fill out like this.
    Then you just turn on the one's you want.
    (like rpm above is enabled, the little speaker vs an "X")
    Chat soon,
  5. Sento Siete
    Valencia (Spain)
    304Coins
    2DOF, SCN5
    This is the error text:
    System.IO.FileNotFoundException: Could not find file 'C:\Users\Usuario\AppData\Local\GameVibe\GameProfiles\LastUsed\AssettoCorsaCompetizione_LastUsedPro.cfg'.
    File name: 'C:\Users\Usuario\AppData\Local\GameVibe\GameProfiles\LastUsed\AssettoCorsaCompetizione_LastUsedPro.cfg'
    at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
    at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
    at System.IO.StreamReader..ctor(String path, Encoding encoding, Boolean detectEncodingFromByteOrderMarks, Int32 bufferSize, Boolean checkHost)
    at System.IO.StreamReader..ctor(String path)
    at GameVibe.Mod_ProfileManagement.‮‍‍‮‎‫‮‬‏‎‮‫‎‪‎‬‎‏‮‏‍‎‌‮‎‏‍‮(String )
    at GameVibe.Mod_ProfileManagement.GameProfileChanged(String GameName)
    at GameVibe.frm_GameVibe.cbo_GameNameList_SelectedIndexChanged(Object sender, EventArgs e)
    at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e)
    at System.Windows.Forms.ComboBox.set_SelectedIndex(Int32 value)
    at GameVibe.frm_HiLow.cbo_GameSelected_SelectionChangeCommitted(Object sender, EventArgs e)
    at System.Windows.Forms.ComboBox.OnSelectionChangeCommitted(EventArgs e)
    at System.Windows.Forms.ComboBox.OnSelectionChangeCommittedInternal(EventArgs e)
    at System.Windows.Forms.ComboBox.WmReflectCommand(Message& m)
    at System.Windows.Forms.ComboBox.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4341.0 built by: NET48REL1LAST_C
    GameVibe
    Assembly Version: 0.2.0.0
    Win32 Version: 0.2.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/GameVibe/GameVibe.exe
    TyKHJUSTxTTwPVWRpLJXewLFkkM
    Assembly Version: 0.0.0.0
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    Win32 Version: 4.8.4300.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    Win32 Version: 4.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    GameVibe_PluginAPI
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/GameVibe/GameVibe_PluginAPI.DLL
    XAudio2_GameVibePlugin
    CodeBase: file:///C:/Users/Usuario/AppData/Local/GameVibe/AudioPlugins/XAudio2_GameVibePlugin.dll
    Microsoft.GeneratedCode
    Microsoft.DirectX.DirectSound
    Assembly Version: 1.0.2902.0
    Win32 Version: 5.04.00.2904
    CodeBase: file:///C:/Windows/assembly/GAC/Microsoft.DirectX.DirectSound/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.DirectSound.dll
    Microsoft.DirectX
    CodeBase: file:///C:/Windows/assembly/GAC/Microsoft.DirectX/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.dll
    enabled.
    For example:
    <configuration>
    </configuration>
  6. Sento Siete
    Valencia (Spain)
    304Coins
    2DOF, SCN5
    That's what I get while running rF2, but no vibe...
  7. Sento Siete
    Valencia (Spain)
    304Coins
    2DOF, SCN5
    Some help, please?
  8. Keith
    Keith Active Member
    Electrician
    Canada, Saskatchewan
    154Coins
    My game vibe has stopped working on most games. I trouble shooted for hours then gave up. I now use simhub for my shakers.
