2dof wiper motor 2021
Discussion in 'DIY Motion Simulator Projects' started by mhchong, May 28, 2021.
  1. mhchong
    mhchong EK99
    freelancer
    malaysia
    - 120Coins
    All the wiring linked to arduino im refer to https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
    Steps for my DIY.
    1. Setup motor and potentiometer
    WhatsApp Image 2021-05-27 at 1.24.36 PM.jpeg WhatsApp Image 2021-05-27 at 1.24.36 PM (1).jpeg WhatsApp Image 2021-05-27 at 1.24.36 PM (2).jpeg
    2. ibt 2 motor driver
    3. install crx wiper on 4040 aluminium profile (4040 is not strong enough, better go for 4080 aluminium)
    4. Setup frame
    5. Build SMC3 v1.0 to arduino
    6. Use SMC3Utils-master to setup wiper motor
    7. Install SimTools_2.5.1 and configure the Interface setting
    8. run LFS before patching it for motion: https://www.xsimulator.net/communit...run-in-first-person-mode-before-patching.365/
    9. Patch setting to LSF
    10. Run again LFS, now the motor should follow the motion
    153,986Coins
    +11,162 / 57 / -2
    Nice work, thanks for sharing your rig :thumbs
    Did you ground isolate the wiper motors?
  3. mhchong
    mhchong EK99
    freelancer
    malaysia
    - 120Coins
    No. I didn't. No wonder i feel little electric shock on the aluminum frame. Thank you for informing me. :)
    153,986Coins
    +11,162 / 57 / -2
  5. mhchong
    mhchong EK99
    freelancer
    malaysia
    - 120Coins
    153,986Coins
    +11,162 / 57 / -2
    Wiper motors vary somewhat in design, but often ground is via the brush to the body of the motor, that is what needs to be isolated and earthed via the wiring not via the structure.
  7. mhchong
    mhchong EK99
    freelancer
    malaysia
    - 120Coins
    Understand. Thanks for let me know my assembly mistake, appreciate.
