Question stuck in project, for dear lord, HELP ME¡¡¡¡¡
Discussion in 'DIY Motion Simulator Projects' started by marco cristopulos, May 30, 2021.
  1. marco cristopulos
    marco cristopulos New Member
    139Coins
    Please help, I don't know what else to do, I read over and over again but it is difficult for me to understand what I am failing in, the engines cannot be turned ON in SMC3 utility, i read the forum, I check the wiring over and over again, I do the steps that everyone recommends but I can't find the solution,
    Cant turn ON motors on SMC3 U.
    154,400Coins
    +11,181 / 57 / -2
  3. marco cristopulos
    139Coins
    yes, did all ... :/
    what do you think can be do?
  4. mhchong
    mhchong EK99
    freelancer
    malaysia
    - 120Coins
    The green line is the potentiometer line, it need to be within the orange and red line, else you could not turn it ON. upload_2021-3-14_19-32-53.png
  5. marco cristopulos
    139Coins
    Here more pictures, hope can help
    154,400Coins
    +11,181 / 57 / -2
    Have a look to see if the pot is properly centered, because if not and it exceeds the limits for safety reasons the motor will not run.
  7. MarkusB
    4,215Coins
    I don‘t understand. In your first post, you wrote that you cannot turn the motors on in SMC3 Utility, and your first screenshot confirmed that they were off.
    But in your new screenshots both motors are ON. So for me it seems that you have solved the problem.
  8. mhchong
    mhchong EK99
    freelancer
    malaysia
    - 120Coins
    try voltage meter test on ibt2 motor driver 12v input, to confirm receive power fr psu.
  9. marco cristopulos
    139Coins
    That's all finally is work
