FlyPT Mover 3.5.3
  1. Bastiuscha
    Bastiuscha Active Member
    750Coins
    Sry short Question. Am i blind, or is there no support for "NoLimits 2 Roller Coaster Simulation" ?
  2. Historiker
    9,214Coins
    It is there, Source: NO LIMITS 2 (TCP)
  3. Bastiuscha
    750Coins
    Yes... found it by my self. You was faster. On the webside i did not found, but in the tool himself.
  4. Marco Annunziata
    919Coins
    Sounds good,
    I'll look forward for a test than the feedback.
    Thanks you
  5. Trigen
    Trigen Active Member
    2,892Coins
    @pmvcda
    Hi mate
    If and when you got time i have a suggestion. I do know this should be possible in 4.0 but i dont know when that is out so if there could be possible to add a pose for just this one thing in 3 that would be fantastic. Low prio though
    Long ago we discussed being in a knife edge in an aircraft
    Roll 45 degree while turning at 1g you will feel some tilt in the rig
    Roll at 90 degree 1g aka knife edge pass. Feel the full 90 degree tilt.
    Roll angles at 1 -2 -3 G you will feel less and less tilt.
    Currently the only thing you can do is to make a DOF from value: vertical acc in the roll axis to cancel out Roll when there is Vertical acc present. The problem is that it does not know which roll direction you have so if you cancel out one direction it wont work the other way because it will add to roll instead of subtracting.
    So what we need is something that is aware of the roll ( or simpler just bring to 0 regardless) direction and is able to cancel out both directions.
    I suppose the only challenge which isnt implemented in 3 is to direct it to work on only one pose or axis in a pose. so it does not cancel out all roll action. Its not quite needed but good to have
    hope this is something you can look into
    Cheers!
  6. Trigen
    2,892Coins
    Ive noticed there is considerable lag on the Transducers. Do you think that will change in the next few versions?
  7. pmvcda
    15,647Coins
    Hope so.
    Working on that one right now. Still early stages on transducers.
    Meanwhile, still having problems on the serial of version 3 and still some bugs to solve.
  8. Thomas Strauch
    Thomas Strauch New Member
    - 54Coins
    Hello, I've been trying for a few days to get my 6DOF rig to run with DCS, the basic movements work. Only everything is too choppy and too fast. But somehow I get stuck with the filters and settings.
    Does anyone have a working FlyPTmover - DCS file for me that I can build on?
    greeting
    Thomas
  9. deadlymanager
    deadlymanager Member
    10Coins
    This is my settings for DCS.
  10. Thomas Strauch
    - 54Coins
    Thanks for the file, let's see what I can do with it.:)
  11. pmvcda
    15,647Coins
    Did not disapear. Been working on the update and the new 4.0.
    The bugs in 3, go deeper than I thought, but I will solve them.
    Meanwhile, a small preview of Mover 4.0:
    This video shows the underline of an hexapod rig. This group of nodes and connections will be shown has one when grouped and will be available to use as one node in Mover.
    So all that mess can be simplified. The idea is to show how deep we can go in customization.
    • Winner Winner x 7
  12. cfischer
    Colorado
    2,789Coins
    This looks not only super powerful but also more intuitive and easier to organize/understand. I really like the improvements to the graph too! Seriously amazing work Fly!
  13. theoptimisticcynic
    theoptimisticcynic New Member
    Marketing (product management - technical devices)
    Connecticut, USA
    108Coins
    3DOF, DC motor
    First, thanks for this awesome piece of software. I'm trying to sort through a bunch of testing before connecting my motors and noticed behavior in the Serial output that wasn't what I expected. When I use serial output and decimal I see true decimal values when Mover is connecting or disconnecting from my source and moving to park position ie values like 319.690693126584, but once it's receiving real axis values coming from a source it seems to only send a whole number. ie. 319.
    I imagine that this isn't an issue for most, but I'm using a recent Odrive firmware that uses turns instead of encoder counts for position control so those extra decimal values are used for fractions of a rotation. I'm still in testing but it seems that extra precision will be key for vibration.
    Is this the intended behavior? Is there a way to get the full decimal value for an Axis value instead of a whole number? I'm using version 3.4.2
    By the way, node based setup looks interesting. Are you planning to have some pre-built node layouts corresponding to specific pose/rig configurations or everyone starts with a blank slate to start?
  14. Trigen
    2,892Coins
    Making a torque mode for servo drive. Trying to use 10 bit in direct for this but it feels like my max number is 255 for the output so i cant convert say 0 1023 to 0 - 255
    I suppose it makes no difference since i have to change the range of the number anyway but id like to know how i get the 10 bit value from Mover into this code so i can use
    If speed > 512 (or any bit values ) and so on instead of 127
    Is that possible or is there another way to go about this?
    Code:
    void loop() {
      // put your main code here, to run repeatedly:
       while (Serial.available())
        unsigned int Speed = Serial.read()  ; // Dont need -48, Mover compensates // divide by 4 to get 8 bit
         //myMotor1->setSpeed(Speed);
          //  myMotor1->run(FORWARD);
        //Serial.println (Speed)
        if (Speed > 128)
            Speed = map(Speed, 0, 128, 0, 255);
           // Serial.println (Speed);
        else if (Speed < 126)
            Speed = map(Speed, 0, 126, 255, 0);
            myMotor1->run(BACKWARD);
         else
            myMotor1->run(RELEASE);
  15. Bastiuscha
    750Coins
    Hey, do someone have a nice "nolimits2" Moverfile for me? Could be nice, someone with a 6DOF linear Actuator Rig. I'm not really satisfied with my setting and I can't find a better one.
  16. Flymen
    Montreal, Canada
    2,476Coins
    DC motor, 6DOF
    I will send my mine soon ( I ‘m at work )
  17. Trigen
    2,892Coins
    Hello
    https://github.com/cubexvr/servoController
    https://www.xsimulator.net/communit...o-mega-for-aasd-15a-and-similar-driver.14421/
    Gonna double post this one.
    One issue i am having using this and im not 100% if its a code thing or a Mover thing. Been using this sketch for quite some time now and this one issue means i really cant trust it completely.
    If i restart my computer and connect to the Ardunio it will just go the wrong way and slam it. My SFX is on the bottom so it will just try and move until the drivers fail but my gearboxes just go full back and rips out whatever is able to be ripped out.
    Now if i keep the power off, turn on and off Mover connection its usually ok but sometimes i have to to do it several times. Something i cant take the chance on really. This is the same on all Mover versions. What do you think could be the issue here?
  18. Trigen
    2,892Coins
    Another issue i see in Mover (3.4 tested but its been an issue) is if i move home position while the Ardunio is not connected in Directs the actuator will do a quick snap then start moving normally the next time i connect. If you change it when it's connected it will be fine.
  19. Bastiuscha
    750Coins
    Please correct me, but if your SFX are wrong, then it should be anything but Fypt.
  20. Thanos
    Electronics Engineer
    2,871Coins
    Yeah, that happens when there are no safeties in the controller. Did you step on the actuators to make sure they are all the way down before powering up? If I remember right, that controller does not calibrate automatically the home position... also maybe you have ground loop or emi noise if the servo ground is not connected to the db25 cable shield...
