News 2dof wiper motor with different spec. Thanks To @noorbeast for help
Discussion in 'Ready, set, go - Start your engines' started by Arta Yasa, Jun 1, 2021.
  1. Arta Yasa
    Arta Yasa Member
    878Coins
    Thank you to Mr. @noorbeast for guiding me, and I have succeeded in building a 2dof wiper motor, even with a different wiper motor, by the way, is it possible to balance the two wiper motors, sir ??
    and sometimes suddenly one of the wiper motors stops for no reason (sometimes stuck min sometimes stuck max then dies) I think bts7960, I tried to switch positions with the running motor, it turns out the bts7960 is normal, I think the pottensio is overturning, I try to turn it in the opposite direction from the stop there is no movement, the wiring is correct and everything is safe, I used a homemade jumper cable with the cable of choice. guess what the cause is, sir ??.
    this is the youtube link of my work and the guidance of Mr. @noorbeast. now I have to learn to perfect the settings before I can buy a more powerful and recommended dc motor. link:
    and is it possible that I will get a DIY license ?? I really hope to get it, so that someday upgrading to the pro is cheaper I really appreciate the maker. Thank you sir
    152,535Coins
    +11,085 / 56 / -2
  3. Arta Yasa
    Arta Yasa Member
    878Coins
    Thanks you so much for your help sir, i will learn more, and it posible to balance 2 dfrent wiper motor with smc3 sir?
    An for req license diy, the url about my project posible to input this sir?? Or make new tread with news and sharing about experience build 2dof sir?
    152,535Coins
    +11,085 / 56 / -2
    The URL here is fine for the license application.
    I am not sure what you mean by balance different motors, you can set different parameters for each motor in SMC3 if you want to, it would likely take some experimentation to get about the same response from different moors.
  5. Arta Yasa
    Arta Yasa Member
    878Coins
    Alright sir, i will try, but I'm still confused about the motor that suddenly stopped by itself, even though the bts7960 wasn't damaged. Is it the potential that is starting to break down, sir?
    152,535Coins
    +11,085 / 56 / -2
    A motor stopping can be a number of things, in SMC3 if the levers move past the designated range it will stop for safety reasons, which is why I have suggested trying to refine your settings.
    Another possibility is overloading and tripping a PSU, as our rigs generate big power spikes in fast reversals. A power cut is likely triggered by big movement events like a crash, where all axis try to move to their limits.
  7. Arta Yasa
    Arta Yasa Member
    878Coins
    Allright sir, thanks you very much sir for your help
