How to repair a servo motor?
Discussion in 'Electronic and hardware generally' started by Banfy, Mar 20, 2021.
  1. Banfy
    Banfy FR/AU
    Australia
    299Coins
    DC motor, Arduino
    Hi all
    I am using multiple servo motors for my gseat
    3 of them have stopped working. I believe the controller board is out of order
    Instead of replacing with new servos, do you know if the controller board can be purchased separately?
    Could find this info so far. Maybe some of you have done this already..?
    My servos are this model:
    https://www.ebay.com.au/itm/Dsservo...ar-Digital-for-Servo-1-5-Redcat-/274394809632
    thank you
    153,830Coins
    +11,151 / 57 / -2
    Whatever that ebay listing is it has ended, so is not available. Better to post the actual details.
  3. Banfy
    Banfy FR/AU
    Australia
    299Coins
    DC motor, Arduino
    the servo is this one:
    DSSERVO DS5160 HV 60kg 180 ° 18T Metal Gear
    but i will probably search for a generic servo controller if it exist
  4. Banfy
    Banfy FR/AU
    Australia
    299Coins
    DC motor, Arduino
  5. Banfy
    Banfy FR/AU
    Australia
    299Coins
    DC motor, Arduino
    Hi fellow electronicians
    i still have this servo model dying regularly
    it starts to be expensive to replace !
    Looking at the photo of the circuit board above, i wonder if this red cylinder in the middle could be a fuse?
    I would be good if i could just replace it to fix my issue
    Do you think it is a fuse?
    what type? where to buy one?
    if I short connect it (i connect both ends directly), is it a way to test if this is the faulty component?
    thank you!
  6. Banfy
    Banfy FR/AU
    Australia
    299Coins
    DC motor, Arduino
    and this is the whole circuit board
  7. physke
    physke New Member
    IT & Electronics Engineer
    Tauranga, New Zealand
    192Coins
    That's a diode.
  8. physke
    physke New Member
    192Coins
    Best to measure it with a multimeter (do not short it out)
  9. Banfy
    Banfy FR/AU
    Australia
    299Coins
    DC motor, Arduino
    thanks
    Are you able to spot a fuse in this circuit?
  10. physke
    physke New Member
    192Coins
    None on this side of the board. What's on the other side?
  11. Banfy
    Banfy FR/AU
    Australia
    299Coins
    DC motor, Arduino
  12. Banfy
    Banfy FR/AU
    Australia
    299Coins
    DC motor, Arduino
    and this is the other side of the board
  13. Banfy
    Banfy FR/AU
    Australia
    299Coins
    DC motor, Arduino
  14. Banfy
    Banfy FR/AU
    Australia
    299Coins
    DC motor, Arduino
    and above show details around the motor
  15. physke
    physke New Member
    192Coins
    No fuses in either of those photos.
  16. Banfy
    Banfy FR/AU
    Australia
    299Coins
    DC motor, Arduino
    Shame ;-(
    Thanks Physke
