  1. ahoenksiluman
    ahoenksiluman Member
    indonesia
    89Coins
    do someone know how to use a3 channel to control the feedback gain..??
    i currently build 2dof rig mover...
  2. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
  3. motiondynamics
    motiondynamics Member Gold Contributor
    1,161Coins
    2DOF, 3DOF, DC motor, AC motor, SimAxe, Arduino, Motion platform, 6DOF
    Hello to all of you dear simulation colleagues.
    I'm going to start using SimTools shortly because a lot of my friends talk about it very well.
    I have never used the SimTools interface and I have never used the PID code (SMC3) because for a few days I have been trying to understand what I need and what to download.
    I am having difficulty knowing which version of SMC3 I should use for my electronic system (Arduino Uno R3 + Monster Moto).
    I think I understand that in the code I have to change a line (MODE1 or MODE2) to "MODE1" because my system requires 3 wires: 1PWM and 2 DIRECTIONS.
    QUESTIONS
    • Is the last (newest) version of the official SMC3 code I can use in MODE1 SMC3 v1.0?
    • In the code "SMC3" I have read 25Khz for Motor 1 and Motor 2, I have read 31Khz for Motor 3. Where is it possible to choose the frequency 25Khz and 31Khz? Where can I select the frequency, from SMC3Utils or Simtools?
    • In the SMC3 v1.0 code I saw "A5 - Motion scaler pot input". I would like to know what the A5r pin is for?
    I don't have very clear ideas, I would be grateful if you give me these answers because I want to start using Simtools right away and I have to purchase the license.
    Thank you
  4. André6969
    André6969 New Member
    22Coins
    Can someone explain-me why is the motor only folowing the inpute line (Blue) in one direction, i have cheked 100 times de conections but I cant figure it out.
    My conections are just like the ones in the foto .
    Any clue to solve it????
    151,467Coins
    +11,039 / 56 / -2
    You need to add more context, for example I presume from the wiring, though am not certain, your are using IBT2s, and if so have you specified Mode 2 in the code?
    In other words you really need to explain fully what you have and have not done.
  6. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    i got this problem before few week, the problem was the ibr-2 (-) or (+) wire not attached correctly i mean one of them not receive power from the psu check them
  7. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,053Coins
    3DOF, DC motor, Arduino, 6DOF
    Check your potentiometers wiring, as I not all potentiometer put the variation pin in the middle. I had that problem once.
  8. Ronan Design
    Toronto, Canada
    1,696Coins
    Can SMC3 control brushless 36V hoverboard motors that use this kind of driver board?
  9. motiondynamics
    1,161Coins
    Hello everybody.
    I have been testing "SMC3 Utility" for a few days and I need some important answers.
    I think I understand that "SMC3 Utility" was created to program the Atmega328P EEprom (Frequency ... PID ... Limits ... etc), but I didn't understand one thing: programming the Atmega328P EEprom will take effect even while using SimTools?
    The following parameters are present in the "SMC3 Utility" software:
    Max Limits
    Clip Input
    Do these parameters replace those of Simtools "Axis Limiting"?
    I think I understand that Max Limits and Clip Input are like "limit switches", correct?
    Or are the limit switches the ones set in "Axis Limiting"?
    151,467Coins
    +11,039 / 56 / -2
    The SMC3 limits are set to define the range of movement available to SimTools, and how those limits are managed by the control board.
    Axis Limiting in SimTools is most commonly used where a given range could result in actual hardware damage, commonly with SCN actuators, or some other specific circumstance where there is a reason for limiting axis movement.
  11. motiondynamics
    1,161Coins
    Hi Noorbeast, thanks for the reply.
    Since I am not very familiar with this forum, I had also inserted this request for help in another section (already deleted) because I did not know which is the right place. Can I write in this section for information on SimTools software and "SMC3 Utility"?
    151,467Coins
    +11,039 / 56 / -2
    This thread is specifically for SMC3, used as intended, and any post should be specific to that, if not a single dedicated thread of your own is where to post questions or progress related to your own intended project.
  13. motiondynamics
    1,161Coins
    Thank you for your support that you are giving me.
    I have a very important question for my experiments:
    I have to convert the PWM signal to analog (0-5 volts). To do this, I don't want to use the RC filter, but I prefer a ready integrated DAC. The question is simple: I read that SMC3 uses 10 bits [1024 passes] (see attached image), but in the SimTools manual I read that it uses 8 bits [255 passes] (see attached image). Should I use an 8-bit integrated DAC or a 10-bit integrated DAC?
    Thanks for your kindness and availability
      270.8 KB
      297
      482.8 KB
      290
  14. MarcelDv
    MarcelDv New Member
    8Coins
    Hi All, i am unsure where i am going wrong, i am using Arduino Uno with a sparkfun monster motor driver. I have an issue with one motor not reversing, i have normal pod response, directions of movement with pods is responding as expected. If i swap motors and pod wiring the swaped motor works fine, at this moment my motor 1 will move in one direction only where motor 2 gives me normal movement up and down.. i have now replaced the MM drivers 4 times tonight i swapped the my last brand new MM driver and still motor one refuses to reverse.. i am using SMC3 version 1.. any advise.. it appears by the led’s on the MM that it is not recieving the reverse PWM signals, when moving down the dir+ led goes on and of, in the dead zone or on the boundry i can se the dir - lightly lights up when i move in the different direction the led stays off.. if i compare it with motor 2 which is working i get the impression the driver is not getting a reverse pwm.. tried all combinations with pwm max, pwm min.. so i do not know where to check next.. thank you in advance for your time.
    151,467Coins
    +11,039 / 56 / -2
    Have you tested the MM: https://www.xsimulator.net/community/faq/monster-moto-testing-before-use.158/
  16. MarcelDv
    MarcelDv New Member
    8Coins
    I have not, thank you will give that a try, the previous MM did work nice both directions and then just out of the blue i had this one way issue and could not get around it.. reading the issues around MM and watching this testing video i am honestly at a point where i am looking for a alternative motor driver to run my Wiper motors.. these MM seems to unreliable by some of the reading i have done now.. is there any good alternative your would recommend for such a motor controller.. something bullet proof if it exist hahaha
    151,467Coins
    +11,039 / 56 / -2
    Sabertooth are pretty bullet proof, but there are a range of other choices depending on your budget and spec needs: https://www.xsimulator.net/community/faq/motor-drivers.11/category
  18. Fedor2091
    Fedor2091 New Member
    - 95Coins
    Hello!!! Can you please tell me if MD13S is compatible with Cytron 13 Amp and SMC3 software? Thank you !!!
  19. Fedor2091
    - 95Coins
    Crookedly wrote sorry !!! Is Cytron 13amp MD13S compatible with SMC3 software?
    Thank you !!!
    151,467Coins
    +11,039 / 56 / -2
