Mechanical Ideas from Neptune
Discussion in 'DIY Motion Simulator Projects' started by SimPotato, Jun 13, 2021.
  1. SimPotato
    SimPotato Member
    Designer
    Gardiner, NY USA
    479Coins
  2. Bontekop
    Bontekop New Member
    Mechanical Engineer
    Hasselt, Netherlands
    107Coins
    Interesting. So this way you can avoid sliders by using hinges. But a shock absorber counteracts the movement. Isn't it better to just use a spring?
  3. SimPotato
    SimPotato Member
    Designer
    Gardiner, NY USA
    479Coins
    Exactly, keep the spring, remove the damper.
  4. SimPotato
    SimPotato Member
    Designer
    Gardiner, NY USA
    479Coins
    Untitled-1.jpg This one is not from Neptune, but from Mercury circa 1959.. Untitled-1.jpg
