Showroom My 3 DOF seat mover + GS-4 + Simvibe
Discussion in 'DIY Motion Simulator Projects' started by Avenga76, Jun 29, 2014.
  1. Halloween2go
    Halloween2go Active Member Gold Contributor
    1,397Coins
    Yeah, Your probably not watching this forum anymore. But I designed my Rig after your build. Except mine is full frame (pedal to seat) Pitch Roll and Traction Loss. Thanks for posting your build. I did use some of your ideas in my Build! Thanks DMAX
  2. João Carlos
    João Carlos New Member
    17Coins
    2DOF, SimAxe
    I am using springs in my project. Soon post here. Thanks for sharing!
  3. Sebj
    Sebj Active Member
    Canada
    492Coins
    Hi @Avenga76, what's new? You still racing or making any changes to the sim?
    Long time since ISRTV exchanges...
  4. djboss001
    djboss001 Member
    Test engineer
    - 34Coins
    Very nice integration of the electronic system! It makes you want to buy a 3D printer!
  5. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
    this looks very nice
  6. Airbas72
    Airbas72 Member
    - 7Coins
    3DOF, Arduino
    Won't the lip spring put additional load on the motors?
  7. Airbas72
    Airbas72 Member
    - 7Coins
    3DOF, Arduino
    Cool belts, every little detail adds realism
  8. mingshuangying
    mingshuangying New Member
    - 1Coins
    2DOF, 3DOF, Arduino, Joyrider
    May I ask what the maximum current your motor driver board can withstand? How much power of motor can be used? The bts7960 I use will not work if the current exceeds 20A. I use a truck wiper motor. There is a gap problem in the worm gear structure. It always makes abnormal noise during use, which is very annoying.
