Question direct drive wheel ideas (HELP!!)
Discussion in 'Direct Drive Wheels' started by lesley, Jun 25, 2021.
  1. lesley
    lesley New Member
    South Africa
    21Coins
    2DOF, 3DOF, DC motor, AC motor, Arduino, Motion platform
    ok soo i am still panning hard to get myself a DD wheel with what i have because i cannot wait to next year to get the 130st servo motor and drive .
    currently what i had was a g27 and dfgt pro,and they both died. the g27 encoder still works as what i'm about to discuss is maybe a ffb plan to the future.
    HardWare:
    1 x Thanos TDD micro aasd 15 controller
    3 x bts 7960 motor drivers
    1 x arduino Rev3 uno
    4 x wheelchair motors (excluding the two logitech wheels )
    i managed to connect the g27 encoder with motor to the tdd board the help of a momo opto LABELED wiring diagram.(encder wiring)
    ENC A (on tdd micro board)= A White(on g27 encoder)
    ENC B (on tdd micro board)=B Black(on g27 encoder)
    5V (on tdd micro board)= 5V Green(on g27 encoder)
    GNF (on tdd micro board)=Grn Yellow(on g27 encoder)
    And what happend was i got actual game input. the wheel goes left and right when i rotate the motor.
    So my whole next idea was, Can i use a bts7960 motor drive or 2 and connect the g27 motors + encoder to have the ffb enabled. (using the DB25 wiring) (i will include images hopefully its clear or u get what i mean). If so could somebody out there please assist with regards to how i would wire the db 25. on the TDD micro i would love to know what wires go into the "torque,index,dir"pins .
    lastly
    please help with mmos 2014 settings when using a 60 cpr. it says u cannot use anything below 256 cpr
    its set to pwm(hbridge).
  2. hideki
    hideki Active Member
    Spain
    - 208Coins
    2DOF, SCN5
    Nice idea/job but the new fanatec DD is quite cheap too. I have 2 old g27 somewhere. If you manage to pull this up I might try it too. Good luck
  3. lesley
    lesley New Member
    South Africa
    21Coins
    Mmmm looking good as a start
