FlyPT Mover 3.5.3
  1. pmvcda
    15,647Coins
    Been looking for the bug, but that's not an easy one :eek:
    Meanwhile, I downloaded your file again and saw the filter in the rig module (for the actuators).
    Could you test without the filter? And see if the behaviour is still there.
    Thanks.
  2. pmvcda
    15,647Coins
    Should be working, at least it works for me.
    But there's some values swapped there and a bug still not solved.
    You have to start FS2020 before connecting in Mover. This specially if you have auto connect enabled.
  3. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,770Coins
    DC motor, 6DOF
    From what I see here could be quite normal behavior. The platform is running full speed from blocked “out of pose” state to the next valid one.
    One suggestion to @pmvcda , could we imagine a smooth transition filter form “out of pose” to the next valid one ?
  4. Ronan Design
    Toronto, Canada
    1,721Coins
    Is there a guide somewhere about how to set it up?
    Do I follow the same SMC3 setup as with the SimTools, and then just use FlyPT to drive it? Will it recognize Arduino based on SMC3, driving 2 IBT-2 boards? Any setup tips?
  5. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    I think, if such a thing is achievable, it would be a great improvement.
  6. Marco Annunziata
    919Coins
    sorry for the late answer, sure in the next few days I will make some tests. The rig is so high-performance that without these filters it risks tipping over despite the weight of 350 kg.
    Thank you
    Marco
  7. Marco Annunziata
    919Coins
    Hi, I just uploaded a new video where you can see that the physical platform gets stuck even though the actuators in the mover continue to move. this behaves happens only when the rig is in the singularity event. I removed the filters in the rig as you advised and I attach the file in order that you could take a look.
    Thank you a lot
    Marco
    • New.zip
      4.4 KB
      343
  8. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    I think „out of pose“ means stopped movement for the whole platform even if only one actuator has reached its limit.
    Maybe I don’t look where I should but for now it’s looking fine to me.
    You just have to avoid those singularities by reducing the motion range of each dof or turn this feature off, which can expose you to eventual problems of not mathematically predictable poses.
  9. Marco Annunziata
    919Coins
    Nope "out of range" mean that the platform can't solve the position because at least one actuator as reached his limits but the geniality of the mover is that he can give you a position despite the unsolved position. To avoid the "out of range" as you mentioned "stopped movement for the whole platform even if only one actuator has reached its limit." You have to enable the option "Stay in last possible position"
  10. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    That’s not the way how I understand it. Mover can’t give you the pose with one actuator stopped.
    What you see actually is a hypothetical position which can’t be released by your physical platform
  11. Marco Annunziata
    919Coins
    That's partly true, what you see in the 3D viewer is not the same the rig are doing when in singularity or "out if range" positions. When in 3D viewer you see the red actuator that's doesn't mean that get the stopped movement for the whole platform, unless you check the "Stay in last possible position" option and that's the magic.
  12. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    Did you made your video with „Stay in the last possible position“ checked or unchecked?
    If it’s checked, I can insure you, that there is no magic to calculate a mathematically accurate pose with one or more actuator „out of range“, so the platform stops completely.
    On the other hand, when this feature is unchecked, what you see in the 3d Model when one actuator has reached his limit, can NOT correspond to the physical platform position by definition of IK.
    It needs all 6 actuators being „in range“ in order to send the platform to the right pose.
    It‘s how I see things unless I didn’t get the basic concept.
  13. Marco Annunziata
    919Coins
    Of course unchecked, as magic I meant that other software stop the platform if in singularity. Is obvious that is mathematics.
  14. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    I understand. Did you tried to match the „pose limits“ from rig module with range of pose module ?
  15. Marco Annunziata
    919Coins
    Actually I didn't, that's could be a good advice, I will try be next days than I'll let you know.
  16. Pepie
    Pepie New Member
    - 26Coins
    Request: Could you please add support for the Need for Speed Games? Would be great!
  17. pmvcda
    15,647Coins
    Had to include a Spectogram module in the new Mover to make better tests on the filters:
  18. pmvcda
    15,647Coins
    They don't have telemetry, and I don't have time to look for hooks (I'm not good at it).
    If anyone want's to do it, I can add sources for it. Or they can use the hook source to put the memory values there.
  19. Avee
    Avee Virtual Pilot
    1,167Coins
    Wow, this will be the swiss army knife of motion simulation. This will allow to do absolutely everything, like a programming language. I hope it won't become too computationally demanding for my CPU.
  20. cfischer
    Colorado
    2,789Coins
    Amazing work! We are going to be so spoiled.
    Might be nice to run this from a different pc that is dedicated to motion control.
