News windows 11 is out
Discussion in 'News' started by paulopsx2, Jun 29, 2021.
  1. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    ok, a huge number of people download and install windows 11 since 20 jun.
    Try to install sim programs and make some tests and of course, return with results.
    cheers !
  2. absyfadhel1
    absyfadhel1 Active Member
    bahrain
    556Coins
    Hi, i ihave installed win11 on my pc and i played assetto corsa ,dcs,xplane,lfs ,nolimit2..etc,,
    all of them work perfect like win10 and i got idk if its real but i thinks i got like 10fps extra on assetto corsa vr
  3. paulopsx2
    brasil
    647Coins
    all plugins and vibe, wind works fine ? my windsim, simmvibe and some fanatec features dont works
  4. paulopsx2
    brasil
    647Coins
    ok, some fresh news: ALL plugins and software works. simvibe, simtools, arduino and fanatec, logitech x56.
    version 22000.65
  5. paulopsx2
    brasil
    647Coins
    New build 22000.71 still fine.
  6. paulopsx2
    brasil
    647Coins
    New build 22000.120 works as well.
  7. paulopsx2
    brasil
    647Coins
    22000.132 all its fine.
  8. paulopsx2
    brasil
    647Coins
    build 22000.184 fine. Until official launch date ( oct,05 ) i still posting this relevant info. after this, only if some build show me errors. tks
  9. paulopsx2
    brasil
    647Coins
    build 22000.194 fine. last update until 05 oct.
  10. Kass55
    Kass55 Member
    PC support
    321Coins
    This is not surprising, Windows 11 is Windows 10 with a few tweaks and a new GUI interface.
    Real benefit to games will come from new DirectX 13, whenever it is released.
    I suspect Microsoft may make this available to both Windows 10 & 11.
  11. 02c5zo6
    02c5zo6 New Member
    16Coins
    Able to successfully test out puts / have the rig move successfully on a windows 10 PC, but our windows 11 PC shows everything working (com ports etc) but actuators do not respond / move.
    153,758Coins
  13. Kass55
    Kass55 Member
    PC support
    321Coins
    Did up upgrade working 10 setup to Win 11, or is this a clean install.
    Without knowing anything about your setup its difficult to suggest anything.
    Other than go through step by step & check what is working
  14. 02c5zo6
    02c5zo6 New Member
    16Coins
    Working without issues now, turned out to be EMI that was resolved with ferrite chokes.
  15. mukinurmorad
    mukinurmorad New Member
    23Coins
    Hey there! I just updated my gaming PC to Windows 11, and while it seems to be working without any issues now, I have to admit I'm slightly disappointed.
  16. mukinurmorad
    23Coins
    I've heard mixed reviews about the update, and it just doesn't seem to have the same feel as Windows 10. I'm even considering switching back to Windows 10. Have you heard about the windows 10 product key Reddit? I've been considering checking it out as an option. Let me know your thoughts on Windows 11 and if you have any tips for making the transition smoother. Perhaps, you can talk me out of switching back.
  17. KWhale
    KWhale New Member
    184Coins
    I just upgraded from Win 10 to Win 11. The motion is all jittery now, like smoothing went to zero -- but it didn't. And even though the tuning center numbers didn't change, I seemed to be getting higher amplitude motion. Any idea what's happening???
  18. Fu Chuanhsun
    Fu Chuanhsun New Member Gold Contributor
    - 215Coins
    I have the same problem.
    I test the motion with my laptop (windows 10). The output test is normal.
    On my new computer (windows 11) , the case is different, when I turn on output test, my 2 dof machine will tilt to left side. When I turn off the test, machine will no not be back the normal position.
    Can someone help?
  19. QuinrodD
    QuinrodD YawVR1
    self employed
    223Coins
    3DOF, Motion platform
    I am still running Windows 10 (Pro 64 Bit), and intend to keep it as long as possible. As I am a VR user (Oculus Quest 2), there at least at first were issues with the Quest in Windows 11. A lot of other quite niche software also has or had issues with Windows 11. Overall, I don't see any real benefit for using 11, its not noticably faster or better in any way, and basically just looks a bit nicer. So stay with 10 if you can :) Heck, I am still running Windows XP on the PC that runs my CNC and Laser Cutters. Since they are not connected to the internet, its totally fine, and the needed software runs only on XP.
  20. Benfotek
    Benfotek New Member
    22Coins
    I like it so far. It's smooth, quick, and generally better than Windows 10. I think Microsoft has come up with the best OS ever. Personally, I have windows 11 pro, what about you?
