My 5 DOF with SFX-100 Build.
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Randy, Jun 11, 2021.
  1. Randy
    Randy Member
    Re-tired
    Glendale,AZ
    449Coins
    Test number 1. Got the inside right but will need to go to 90 x 90 to get full contact with the tube with the 3" PVC.
    May even look into trying 2" PVC ?
  2. Randy
    Randy Member
    Re-tired
    Glendale,AZ
    449Coins
    Been going over the Sim with my Wife and I'm going back to the original plan. I will build the SFX-100 .
    Its the size that is pushing me into it. Now I will start looking for a traction lose system for it
  3. Randy
    Randy Member
    Re-tired
    Glendale,AZ
    449Coins
    Been printing some parts and trying to learn Solidworks . Looks like its going to be up hill all the way.
  4. Randy
    Randy Member
    Re-tired
    Glendale,AZ
    449Coins
    So how much traction lose is ? How about 130mm total,75mm L and R.
    153,740Coins
  6. Randy
    Randy Member
    Re-tired
    Glendale,AZ
    449Coins
    What happened to "more is less" thing ? LOL
    153,740Coins
    I actually agree with that, I am just flagging common member approaches ;)
  8. Sim Freak
    Sim Freak Sim Freak Gold Contributor
    61Coins
    It depends on where you place the actuator, relative to the pivot point for the TL platform. The closer they are the shorter stroke, speedier effect but less details.
  9. Randy
    Randy Member
    Re-tired
    Glendale,AZ
    449Coins
    Pivot will be about 1305mm.
  10. Randy
    Randy Member
    Re-tired
    Glendale,AZ
    449Coins
    What infill are people printing at ? 30%,70% ?
  11. Thanos
    Electronics Engineer
    2,907Coins
    I'd suggest 85% with 10 walls...
  12. Randy
    Randy Member
    Re-tired
    Glendale,AZ
    449Coins
    More parts.
  13. Randy
    Randy Member
    Re-tired
    Glendale,AZ
    449Coins
    Been trying different slides. Now I have started trying one on my own. In the photo their is a small crosection of the new one. Wanted to see if it fit before printing the hole thing. We will see. The 100x100 was from eRacing and the STL's on SFX-100 will not fit, way off .On a side not I have used 2Kg. of PLA to get to this point. LOL
    But I have 5 spacers and a mount for my boat that are good. And its all good.
    Can't seem to get my head around Solidworks. Been using Tinkercad and that I can make work, but I'm slow with it. Got 2 books for Beginners and one more coming for Tinkercad. May it will be the one ?
  14. Randy
    Randy Member
    Re-tired
    Glendale,AZ
    449Coins
    First try. But it needs some tweaking.
  15. gigi
    gigi Active Member
    919Coins
    2DOF, JRK, 4DOF
    Hi, I too would like to change the power cables of my motors by installing new shielded cables. I would like to do this by recovering the connectors that are on the non-shielded cables. The problem is that I don't know how to disassemble these connectors to reuse them with the new shielded cable and I don't want to ruin them in the attempt to do so. Do you have any information or help to give me? Thanks
  16. cfischer
    Colorado
    2,807Coins
    They are threaded together and the wires are soldered. Just be gentle when unscrewing by hand and you should have no trouble.
