drtikol's 2 dof Seat shaker
Discussion in 'DIY Motion Simulator Projects' started by drtikol, Aug 1, 2016.
  1. drtikol
    drtikol Member
    Czech Republic
    292Coins
    2DOF, JRK
    Thanks again but I explained it wrong. I have set it to +-40 deg from neutral position and it works Ok within this range most of the time but just after a while of driving under heavy breaking it just "fall" through the 40deg barrier to the very bottom and unable to return to the ange by itself
    151,467Coins
    +11,038 / 56 / -2
    If your settings and PID can't stop the overshoot then you need to reduce the range, and as I suggested at the same time tweak your PID settings if you can squeeze out a bit more control.
  3. drtikol
    drtikol Member
    Czech Republic
    292Coins
    2DOF, JRK
    Thanks for your patience. I was afraid of messing with PID but looks like there is no other way. Will do and let you know. Thanks again
    151,467Coins
    +11,038 / 56 / -2
    PID is one of those dark arts, a bit like refining a motion profile, part of it is how you understand and go about it, but the other half is that it is somewhat specific to the hardware and design used, here is a soft entry (ignore the JRK specific stuff), with includes links to more technical aspects, depending on how far you want to go down the PID rabbit hole: https://www.xsimulator.net/community/faq/a-laymans-analogy-guide-to-pids-pid-tuning.219/
  5. drtikol
    drtikol Member
    Czech Republic
    292Coins
    2DOF, JRK
    First full lap! Still too excited to drive decently but rig looks like alive and working properly!
    151,467Coins
    +11,038 / 56 / -2
    Great to see your rig in action :thumbs
    It may be the angle but something looks a bit odd with sway, it should lean away from a corner and roll should be set opposite that.
    Do you have heave configured, it is a bit hard to tell from the video?
    Here are some tips on refining a motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  7. drtikol
    drtikol Member
    Czech Republic
    292Coins
    2DOF, JRK
    Thanks for immediate feedback. I may be stupid but I thought that I should configure Surger and Sway only in case of 2DOF rig. Are you saying I should configure all the forces for the 2 axis (2x interfaces) I have?
    151,467Coins
    +11,038 / 56 / -2
    Even on a 2DOF configure sway, surge (simulated), heave (simulated), roll and pitch, it will add so much to the experience.
    Follow the tips and initially do each axis individually, then turn them all on and tweak from there.
  9. drtikol
    drtikol Member
    Czech Republic
    292Coins
    2DOF, JRK
    I've done quick config for five forces and it really came alive now.
    151,467Coins
    +11,038 / 56 / -2
  11. drtikol
    drtikol Member
    Czech Republic
    292Coins
    2DOF, JRK
    After some refinement it looks it works ok without any lever drops.
    151,467Coins
    +11,038 / 56 / -2
    Is paint on the to do list, or are you having way too much fun for that just yet :grin
    • Funny Funny x 2
  13. drtikol
    drtikol Member
    Czech Republic
    292Coins
    2DOF, JRK
    You know the answer:grin
  14. drtikol
    drtikol Member
    Czech Republic
    292Coins
    2DOF, JRK
    After "few more changes/updates" I think I'm getting there. I hope the rig found it's permanent place. I had a very refreshing Assetto Corsa session yesterday and it feels "natural" to have seat motion, just adds to immersion. Planning to do some video to show everything working in the same time.
  15. drtikol
    drtikol Member
    Czech Republic
    292Coins
    2DOF, JRK
    So I tried to do some racing video using my Seat mover
    Since that I have re-installed Game Vibe to control my 2x Bass shakers and...oo boy, it adds som uch to the feeling. Just o feel engine revving on your butt..:grin Not sure how to capture vibrations and the joy of using it.
