My 2dof simulator
Discussion in 'Ready, set, go - Start your engines' started by elvis77, Jul 12, 2021.
  1. elvis77
    elvis77 New Member
    11Coins
    Hello, I have started making a 2Dof. I followed the wanegain tutorial but with a motorcycle monster shield card and potentiometer directly coupled to the 12 volt wiper motor. I installed 2 motorcycle monster cards since they were defective on one channel, so 1 card per motor. It works pretty well but my 12 volt power supply comes from a PC and cuts very often I think it lacks power.
  2. elvis77
    elvis77 New Member
    11Coins
    I fixed my power supply problem that was cutting. I put a motor power supply and it works very well. I bought the simtools license but I didn't know that I still had to pay for the plugins IMG_20210722_175501.jpg IMG_20210722_175609.jpg IMG_20210722_175655.jpg
    153,986Coins
    +11,162 / 57 / -2
    SimTools (motion Software) and Xsimulator.net (community and community developed plugins) are two different entities: https://www.xsimulator.net/community/faq/simtools-and-xsimulator-partnership-explained.275/
    Plugin access is either via 250 forum activity coins or a membership package: https://www.xsimulator.net/community/faq/coins-and-how-to-download-plugins.2/
    But you can use the included and fully functional Live For Speed plugin for testing, just make sure you run a race in first person mode before patching it for motion: https://www.xsimulator.net/communit...run-in-first-person-mode-before-patching.365/
  4. elvis77
    elvis77 New Member
    11Coins
  5. elvis77
    elvis77 New Member
    11Coins
    I changed the fixing of the potentiometer with a leather belt fixed directly on the square of the motor and it is perfect. I ventilated the engine and added flywheel pedal attached to plumbing pipes. this system and adjustable thanks to the drawer slide fixed on these pipes
  6. elvis77
    elvis77 New Member
    11Coins
    my simulator a little modified with the addition of a hotas x
  7. orhan
    orhan New Member
    28Coins
    as I see you use two power supplies, one of them dedicated to control circuit (arduino) and the other for motors I guess. is it true? cograts, good work.
  8. elvis77
    elvis77 New Member
    11Coins
    thank you ! no the two power supplies each control a motor and the arduino and powered by the PC
