Question SEGA RALLY 3 ARCADE Actuator test HELP.
Discussion in 'Commercial Simulators and Peripherie' started by SBDESIGN, Aug 4, 2021.
  1. SBDESIGN
    SBDESIGN some knowledge
    director
    125Coins
    2DOF, SCN5
    Is this possible.
    I have a sn5 rig for good few years now - and why I am member.
    But this question relates to the ..
    SEGA RALLY 3 Super Deluxe Arcade machine
    It is windows XP based.
    I can't find info on what the actuators are.
    The motion doesn't initialise,
    There is a feedback control with a display per actuator.
    In the game bios settings (test menu) it errors, but if you manually move there is a max min limit switch, which engage fine.
    Due to my knowledge building my own, I thought asking here maybe something - as limited resources if any available for the specific machine.
    Is there a generic way to test actuators, without using a pc, just power? and perhaps a pot to turn to increase decrease them?
    any help appreciated
    152,535Coins
    +11,085 / 56 / -2
    With such old limited hardware, plus so little information about it, it may be easier and more cost effective to just replace the actuators.
    But for now post pictures of the hardware, and any serial numbers you can find, to see if anyone here can identify it, so you at least know what you have.
  3. Gadget999
    12,035Coins
    a side question - is it possible to download and run sega rally on a pc / emulator ?
  4. SBDESIGN
    director
    125Coins
    2DOF, SCN5
    Yes with tekkieparret
    the real arcade is sega hardware: europa-R
    and the europa-R =
    Europa-R PC Specs.
    intel DG33BU Motherboard
    Pentium E8600 dual core 3.4ghz cpu
    8Gb ram
    Nvidia 8800 (or 9800, GT640, GTS450)
    MP9835L dual serial port with parallel cable (for sega FFB board)
    Case with 400W PSU that'll fit inside the base of the SR3
    120-250Gb Sata HDD
