FlyPT Mover 3.5.3
  1. hannibal
    hannibal Active Member
    4,490Coins
    i need simshaker.. cause simshaker allows specific game sounds to shake... like firing guns, landing gear, wing buffet and stall...
  2. hannibal
    4,490Coins
    will look into this during the week..
  3. Flymen
    Montreal, Canada
    2,424Coins
    DC motor, 6DOF
    Hi , Pedro *Mr Tony Stack *;)
    Yes , I use Motion compensation soft and I have just one of this module active .
    iF YOU close or reopened the motion . ( yes and no ) :think
    Normaly , when I open set up , I choose my game to play / Open and in my column of outputs only Motion compesation is on ( red square) .
    Just before to start all outputs , Motion compensation is still red and ready .
    I start all outputs and the others goes orange/red and everything goes well .
    and after this , if I stop all outputs , only Motion close and all others stay red with the message error !! ( but sometime the processus work well ) !!!!
    I did some test today ( no rig ) and if I close Motion compensation before to start all outputs it seem to be good !!
    I can't see again this message after this processus !
    Thanks !
    Eric
  4. pmvcda
    15,372Coins
    All coming in the next update.
    Had to make some detective work to get that data.
    Had to look at the byte array and search the values... :confused:
    @hexpod knows how it was....
  5. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,637Coins
    DC motor, 6DOF
    Oh yea, this will for sure put the game on the ultimate level of realism. Well invested efforts - bravo !
  6. hannibal
    4,490Coins
    thats a big feature, cause simshaker does an amazing job.
    i mean, they have effects/triggers that apply specific aircraft.
    recently i had to go simshaker beta install in order to get it to work with the recently release mi24 p hind.
  7. hexpod
    berlin
    7,637Coins
    DC motor, 6DOF
    I think as well that aircraft type detection is the way to go for aircraft specific profiles.
    This is something @pmvcda could seriously consider
  8. pmvcda
    15,372Coins
    It's possible,
    I can try with one of the aircrafts
  9. pmvcda
    15,372Coins
    Mover 3.5.0
    -Update to IL2 Sturmovik. Now with extra data, ground detection and air-ground-air transition.
    NOTE: Go here: https://www.flyptmover.com/sources/games#h.u80h8yeu4f0t
    You need to update the IL2 setup to get the data.
    -Corrected Thanos order of actuators.
    -Added online shared setups (experimental).
    -Tried to solve some problems on Project Cars / Automobilista2 sources.
    -Some updates on FS2020 source to solve some bugs.
    -Unfortunately, not all bugs solved.
    We can now browse online shared setups:
    You can share your setups:
    To remove or update them, they are shared with a user, password and name that you need to specify when sharing them.
    This is WIP! Right now, the Setups list is empty!
    Please don't destroy the server.
    • Winner Winner x 6
  10. hannibal
    4,490Coins
    trying to download to check out.. but it says i need email access ?
  11. hannibal
    4,490Coins
    @J-1775
    i was trying understand your P51 profile..
    i noticed that for Main All 6Dof for Air, under Sway, you set EMALP for 150... (maybe you meant for the setting to be 1500?) but most other DoF of sway and surge, you set it to 1000-2000, im wondering if this was intentional...
  12. ikesimuladores
    ikesimuladores New Member
    Brasil
    80Coins
    I'm trying to download, but it says access is denied and I will receive an email
  13. pmvcda
    15,372Coins
    Sorry, it was to late...
    Should work now
  14. pooh
    pooh Member
    584Coins
    out of curiosity, what was the issue with PC2/AMS2? i'm asking as it was working 100% fine for me :) or so i thought :)
  15. pmvcda
    15,372Coins
    There was some complains when going to the garage or restarting, with sudden movements in the rig.
    Not sure if what I made solved the problem, did not test it on the rig.
  16. ikesimuladores
    Brasil
    80Coins
    OK
    Thank you very much
  17. Zeeflyboy
    Zeeflyboy New Member
    125Coins
    Hey guys can anyone help me troubleshoot why I can't get any telemetry out of MSFS2020?
    I have MSFS working with SRS fine, which suggests simconnect is working there at least... and of course referring to the flyPT MSFS section is says no setup required.
    If I set up eg IL2 as a source in FlyPT I can see telemetry data changing as I fly, but if I set up MSFS 2020 as source it detects the game (click connect and it goes yellow), but never picks up any telemetry when I go and fly about.
    Cheers for any suggestions.
  18. Zeeflyboy
    125Coins
    Solved - turns out if I open Mover before MSFS it doesn't work. If I wait until MSFS has fully loaded before I open it then it does!
  19. Psionic001
    Sydney
    1,006Coins
    Motion platform, 6DOF
    @pmvcda thanks for another update. Your work is amazing and I look forward to exploring shared profiles/setups.
    EDIT: Just had a go ov V3.5 in MSFS2020. Roll axis was reversed from the defailt in V2.4.2 so I reversed it back and it flew well.
    BUT having the skids on the ground gave me very Vilont glitches and jerking around untill I was skids-off the ground.
    It looks like the motion Pose is getting both air and ground from a single source without adjustment for each seperately. Other than turning off the simconnect ground source, how would we tune the ground handling for helicopters to soften it up a bit?
    Cheers
  20. hexpod
    berlin
    7,637Coins
    DC motor, 6DOF
    What are the helicopters you use in 2020 ?
