Miaziol 2dof + traction loss
Discussion in 'DIY Motion Simulator Projects' started by miaziol, Aug 10, 2021.
  1. miaziol
    miaziol Member
    Poland
    - 60Coins
    I decided to build my 2DOF + Traction Loss platform. The whole is a fairly heavily inspired by the platform from Dofreality as you can see on the appended photos. Most work do it alone, i.e. cutting welding. Some elements have been drawn in CAD and cut out using a laser. Of course, I can share DXF files if someone needs.
    I decided to use Transtecno engines exactly the EC250.240 model, these are 24V 350W (S2) engines. Each engine will be powered by a separate 24V 30A power supply and I wonder about the choice of drivers. There is a delicate problem with availability and my choice boils to MD20C or MD30C. The steering wheel is a Big Mige engine when it comes to pedals, I have a built copy of Heuskinveld. Regards, all advice is welcome. My English is not the best also sorry for any mistakes.
    230729540_1209179649604377_27349780697445837_n.jpg 227329942_193638695994096_7454666656338755180_n.jpg 231445644_980991232659404_1573503919319225643_n.jpg 231420200_10217585781315149_6089192434645007927_n.jpg 226925645_352816272995230_5717937153279840787_n.jpg 231971701_10217585779875113_6968597989579930195_n.jpg image0.jpg 225534930_831407137515829_628793259558076270_n.jpg 222733592_861905941424803_121989949172825881_n.jpg
    153,986Coins
    +11,162 / 57 / -2
    Nice work :thumbs
    Do you have a link for the engines used?
    What pots or sensors are used and how are they mounted?
  3. miaziol
    miaziol Member
    Poland
    - 60Coins
    Hi
    DIY hall sensor pots, I don't have link but I have a PDF with all needed data
    153,986Coins
    +11,162 / 57 / -2
    Do you have pictures of the completed rig?
  5. miaziol
    miaziol Member
    Poland
    - 60Coins
    Not in this moment, im work like a driver, 2 weeks in job, 2 weeks in home, so my rig is still under construction. I be in home in next week. I have little problem with my cnc milling machine but if everything went ok it will be ready over next two weeks.
    153,986Coins
    +11,162 / 57 / -2
    Just checking if you have a progress update?
  7. miaziol
    miaziol Member
    Poland
    - 60Coins
    just painting today, tomorrow a trip to the shop for cutters and I'll be milling the engine levers. I will try to post some photos with progress tomorrow.
  8. miaziol
    miaziol Member
    Poland
    - 60Coins
    Litlle upgrade. Still not work, now i try run elektronics. E7E8EFC0-D4EF-499C-87EA-32216BF0F71E.jpeg
  9. miaziol
    miaziol Member
    Poland
    - 60Coins
    A small update, box with electronics ready, I am not quite able to set a smooth movement and properly control the engines with PID. Any changes in Ki cause nervous movements until the engines are stopped. For now I used IBT-2 because of the problem with the availability of anything else. For now, KP I have set to 130 the rest of the parameters on 0, PWMmin on 20 and PWMmax for 200, I will have to work on these settings soon. Unfortunately, unfortunately, three times breaks because I have to go to work. There is time to purchase a simtools and plugin license
    5A7F545B-DECC-4DCF-8F7A-6C4D665F9C7A.jpeg 6DBC70B9-E1E9-45CF-B092-6A3F43955F88.jpeg 25430D9C-800D-4275-9DD2-118DCF8DD3FB.jpeg
  10. miaziol
    miaziol Member
    Poland
    - 60Coins
    I have two big problems, the first is I can not properly drive the motors and set the pid loop correctly. Sometimes they start to shake and I don't know why. The second problem is the interference from my osw. Emi noise is such that my steering wheel movement causes the platform to move. Shielded cables, I tried different ports on the computer, I physically removed the base from the platform. The glitches are still there.
    153,986Coins
    +11,162 / 57 / -2
    You can apply for a free DIY SimTools license, see the FAQs here: https://www.xsimulator.net/community/faq/request-a-free-diy-simtools-2-0-license.263/
    Shielding sound like it needs improving, are there Ferrite Magnets used on the USB and pot cables?
  12. miaziol
    miaziol Member
    Poland
    - 60Coins
    Emi now not a problem I run Simtools on another computer and this problem go away. But I stil have problem with oscilating. It start and my ibt2 stop working I must reset it and it work again :( I show you some photo. Zrzut ekranu (8).png Zrzut ekranu (7).png Zrzut ekranu (6).png
  13. miaziol
    miaziol Member
    Poland
    - 60Coins
    Hi
    I have a problem like in the movie, when I do a test in simutils everything is ok, the movement is smooth the graphs overlap. When I start the game it is like in the video. Sometimes one of the engines stops working. I am messing with the pid settings, but I can't get the correct settings all the time. I also have a problem with interference and here I really don't know what to do. When even the car stands still, but I move the steering wheel, the platform works and even goes crazy. I have no idea what is going on. The platform is connected to a separate computer, there are ferrite filters on the cables, I used emi filters in the power supply branches, both the steering wheel and the platform. I am currently waiting for other drivers and potentiometers, for now I have home-made potentiometers based on hall sensors.
    153,986Coins
    +11,162 / 57 / -2
    Sounds like it may be a grounding issue.
  15. miaziol
    miaziol Member
    Poland
    - 60Coins
    everything is grounded, I try driving without my wheel and nothing change.
  16. miaziol
    miaziol Member
    Poland
    - 60Coins
    it seems to me that the problem is the gears that have quite a lot of backlash, I do not know how to get rid of it. As a result, the motors cannot determine the exact position. Hence, it probably comes from shaking. I have no idea what to do with it, I thought maybe about putting on some springs or something like that. i changed the drivers on Pololu 1455, i am trying to set them up. Now I have that at the moment when I am trying to perform the output test. I am able to move the platform once or twice and they lock up, I have no idea where the problem is
  17. miaziol
    miaziol Member
    Poland
    - 60Coins
  18. miaziol
    miaziol Member
    Poland
    - 60Coins
  19. miaziol
    miaziol Member
    Poland
    - 60Coins
    Hello
    After some time, it was time for a change in my setup. The cheap Chinese gears were replaced with SFU gears from DOF Reality. At the same time, the changes go further and a new power supply, 24V 1200W, drops in. The two drivers are replaced with Sabertooth 2x32A, which forces the use of a second arduino on the RTL.
  20. Capitanbrown
    Capitanbrown New Member
    España
    64Coins
    hello.
    Could you put links to the improvements you made?
    Have you noticed differences in softness?
    Could you post a link to a video that uses it?
    :p:p:p
