FlyPT Mover 3.5.3
  1. Psionic001
    Sydney
    996Coins
    Motion platform, 6DOF
  2. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,770Coins
    DC motor, 6DOF
  3. VirtualObsession
    IT developer
    Hertfordshire, UK
    280Coins
    I've been testing No Limits 2 telemetry on my 6 dof motion rig. The roll speed telemetry seems to be doing snap movements which are inconsistent with visuals. Seems a bit bugged to me. Wondering if anyone else experiences that..
  4. pmvcda
    15,647Coins
    I will look at the data.
  5. VirtualObsession
    IT developer
    Hertfordshire, UK
    280Coins
    Thanks. I tested the rollover filter with roll position, but found movement very violent on vertical loops with mostly pitch changes. Roll speed exhibits the same rapid movement, with the direction switching violently where no roll appears to be visually happening.
  6. Bastiuscha
    Bastiuscha Active Member
    750Coins
    Awesome new Update @3.5.0! :) But is it possible, that the Position of the Master Window i not stored anymore?
  7. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    Unfortunately master window was always appearing on the main screen. Could be OS limited.
  8. pmvcda
    15,647Coins
    @hexpod and @Bastiuscha ,
    I can store the position.
    Removed it, because when sharing setups, some windows where showing beyond limits of screens in users with less screens.
    But, I'm now limiting the modules position to the screens range, so I think I can change it back.
    If the main window is not accessible, you can't do much, so in current version it should show in the center of the main window.
  9. Bastiuscha
    750Coins
    @pmvcda Could be nice, to bring it back.
    On my Monitor, the main Window appears on the upper left side now. All other Windows store still there i set them.
    On my 3440x1440 Monitor (i use only one) i had never a Problem before.
    But again, thanks for your nice Work! I love your Tool. And now, i will give you another Donation.
    I think, it's Time for it. :)
  10. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    That would be really cool
  11. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    @pmvcda Maybe one could imagine that you start mover always with tray icon so if the position is outside the screen area you can bring it to main screen from tray menu.
    It would allow to save the main widow on the 2nd 3rd screen which I find very practical
  12. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    I can’t imagine another better solution than second touch screen for tuning “on the fly” the settings of mover.
    I imagine it is even possible to create a 2nd virtual screen on the tablet for this purpose
    Edit:
    Direct access and no disadvantages due to 2nd network computer
  13. Skuldi
    Skuldi Member Gold Contributor
    Germany NRW
    265Coins
    Did someone test 3.5.0 with IL 2? At my end, only the pre 3.5.0 data works and fly pt refuse to use my ground pose.
  14. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    Not yet, I’ll do all tests by the end of the week
  15. pmvcda
    15,647Coins
    Strange, which aircraft?
  16. Skuldi
    Germany NRW
    265Coins
    Aircrafts i testet:
    BF109 E7, F4, G14, K4
    FW190 A5, D9
    Ju 52
    BF110E2
    ME262
    Tempest MK V
    Spitfire MK.IXe
    I also testet the Ju 52 on all maps.
    "Amount of air" stays at 100% on the airfield and i get no data output for everything below "Pitch acceleration".
  17. pmvcda
    15,647Coins
    My fault!
    Forgot to say, that you need to update the setup file in IL2.
    Go here:
    https://www.flyptmover.com/sources/games#h.u80h8yeu4f0t
    I explain how to setup the file.
    If it's still not working, try to use decimation=2 in both fields.
    Please give me some feedback, if it's working after this.
  18. johnnhyzuo
    johnnhyzuo New Member
    50Coins
    DC motor, AC motor, 4DOF, 6DOF
    New
    Hello, I am trying to make 4DOF using fltpt mover. I configured the filter LOGISTIC(EMALP(SPIKE(VALUE;0;50;1);20);20;1) in the mix sway in roll, but it will scroll left and right in the game, which will cause my The simulator bounced very violently. I hope I can get your help. best regards
  19. johnnhyzuo
    50Coins
    With DiRT Rally 2.0, when I drove the car under a cliff, the G force would bounce on the floor when the car rolled, which would make my neighbor call 911. I tried the spike filter and the collision was well controlled, but The inability to solve the tumbling makes me a very headache.
  20. Skuldi
    Germany NRW
    265Coins
    Now it works! Thanks pmvcda:grin
