Bug Simtools problem
Discussion in 'SimTools DIY Version' started by jakanana, Aug 12, 2021.
  1. jakanana
    jakanana New Member
    - 77Coins
    Hello all, i build a seat mover simukit sk1 2 years ago and all worked well with simtools ... but from 1 week not :
    When i launch simtools my seatmover move without problem if i put on on output testing, so off, i try again output testing and i've got 2 short beep and nothing hapen . I put off, on : 2 beep .
    I close simtools, relaunch it, try output testing it works , put off and then on and again 2 short beep and no move .
    I change usb cable, same thing, check on another pc, it works !
    So i make a recovery with a fresh instal of windows.
    New instal of simtools ( latest version) , game, plugin ,etc : it works well ... only 5 days and i don't know why .
    I've got same problem, it's like simtolls loose the port com conexion after 30 seconds ...
    Any idea somebody ? I'm tired to my last week ...
    Sorry for my bad english !
  2. yobuddy
    51,557Coins
    Antivirus maybe?
    What all did you install in those 5 days?
  3. jakanana
    jakanana New Member
    - 77Coins
    Antivirus is what i thinked, so the first time i closed avast and no change.
    After my new fresh instal of windows, i do not instaled avast, i stayed with the microsoft antivirus . And all worked great during 5 days, when bugs come back , i tried to stop the antivirus too and no change ..
    What i instaled during those 5 days ? :
    Simtools, simhub, steam, simcommander, pcars 2, dirt 2 that's all .
    It works thuesday, i close the computer, i open it yesterday and it works 1 time when i use output testing, after that : 2 short beep .
    153,986Coins
    +11,162 / 57 / -2
    If you disable simhub and simcommander do you still get the issue, as it may be a conflict between apps.
    You could also check the Windows logs for any disconnects.
  5. jakanana
    jakanana New Member
    - 77Coins
    Yeah good idea ! I disable simhub and it works ! For the moment :thumbs
    So i put a key to simhub like i see on an another thread here : exclude simtools port com .
    I try pcars2 with both app and it works . I hope that's only that . I don't know why after 2 or 3 years it gone wrong one day .
    Thanks my friends ! hug:
