Newbee
Discussion in 'New users start here - FAQ' started by Hermant Alexis, Aug 20, 2021.
  1. Hermant Alexis
    Hermant Alexis Member
    238Coins
    I just got my first new 2dof system from simukit.
    Nearly finished the building so watching the next step with simtools.
    I hope it will not be too hard to understand/setup, and maybe will need some help :)
    Alexis, from Belgium
    153,764Coins
    +11,149 / 57 / -2
    Looking forward to your update and you wil find members here freely share their experiences and expertise where they can.
  3. Hermant Alexis
    238Coins
    Hi
    I've installed SIM TOOLS without license and LFS for testing.
    I've read already lot of informations and I believe it's enough to make first tries... but not sure.
    For now, the SIMUKIT arduino is connected and when I do "output testing" the both 2DOF motors do always the same move. There is something I do bad....
  4. Hermant Alexis
    238Coins
    Perhaps from these screenshot somebody could find a bug in the setup... :)
      265.2 KB
      364
      205.8 KB
      363
      362.2 KB
      363
  5. Hermant Alexis
    238Coins
    Whatever I put in the "output testing", the two motors always do the same move... even if I put no entries at all.
    And it apply when I click from 'turn on' to 'turn off', but I suppose it's the normal behavior of this button...
  6. Hermant Alexis
    238Coins
    Also I had to dis-engage the potentiometers from the motors and turn them a bit. Without that nothing was moving... well still a bit lost but not say my last word :)
    153,764Coins
    +11,149 / 57 / -2
  8. Hermant Alexis
    238Coins
    I did a run in practice mode (first person = cockpit view I presume?), but didn't see I had to patch.... I do a try... (but do I need to download the patch? I beleived it was free for testing..?)
  9. Hermant Alexis
    238Coins
    Perfect with Axis1a setting I've finally the two motors working fine ! Thanks a lot.
    I go on... :)
  10. Hermant Alexis
    238Coins
    Ahaaaah It's now working with LFS ! Great!
    Need now to play with the strenght of the settings... happy :D
    153,764Coins
    +11,149 / 57 / -2
  12. Hermant Alexis
    238Coins
    Thanks, I've just posted about that point. Not easy to have something good to drive...
    I'm checking the link !
  13. Hermant Alexis
    238Coins
    It's slowly improving...
    If I feel the acceleration is too hard versus the deceleration. As I only can up/down the %surge for these 2 effect together, how could I push just the braking but not acceleration?
    153,764Coins
    +11,149 / 57 / -2
    In the Tuning Center you can manually set Max and Min with different values, which will give a sharper response in the direction of the smaller value, over a shorter range, and a gentler response for the larger value over a bigger range. Differentiating the Min and Max values is often used to also simulate gear changes: https://www.xsimulator.net/community/faq/snappy-gear-change-motion.121/
  15. Hermant Alexis
    238Coins
    Ok thanks.
    And for the overall balance between for example surge/sway/heave, will I have the same behavior if I put 50%/50%/50% VS 30%/30%/30%? I presume but to be sure to well understand the system...
  16. noorbeast
    153,764Coins
    +11,149 / 57 / -2
  17. Hermant Alexis
    238Coins
    I talk about the % in axis assignment like on the screenshot..
      265.2 KB
      356
  18. noorbeast
    153,764Coins
    +11,149 / 57 / -2
    See both the SimTools Manual and the FAQs, for a 2DOF the total of all allocations should add up to around 100%, in practice you can go a little over as all axis are unlikely to be at their extreme except in a crash: https://www.xsimulator.net/community/faq/axis-assignment-percentage-totals.120/
    Use the motion profile tuning tips in the FAQ to help determine how much % you add for each axis, initially refining each individually: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  19. Hermant Alexis
    238Coins
    I wanted to go on my tests this evening but nothing work anymore.
    I just restarted my PC and powered on the 2DOF and the output tests do nothing now... ??
    What could happen as I didn't changed anything in the hardware/setup?
    I try several things but don't find for now...
    Should I re-install simtools?
      362.2 KB
      352
      362.2 KB
      345
      362.2 KB
      362
  20. Hermant Alexis
    238Coins
    Ok solved, I had to uninstall COM1 in panel configuration windows & reconnect arduino USB cable (COM1 appeared duplicate in the list of ports)...
