SimTools v2 - Video Ride Creator v2.1
Create video ride films for the Video Ride Player
  1. accelero
    accelero Member
    france
    189Coins
    2DOF, AC motor, Arduino
    as you can see the cat doesn't like the platform is moving !! so OUtput testing is working perfectly Capture d’écran (5).png
    this a an example of telemetry data that is flowing in the roll pitch.......labels
    these are the Axis assignments for Default and VideoRidePlayer
    thanks
  2. yobuddy
    51,181Coins
    Even cats like simulators :thumbs
    May I have a pic of the VideoRidePlayer running the video.
    (With the game engine's 'tuning center' window open please.)
  3. accelero
    accelero Member
    france
    189Coins
    here we are
    thanks
    Got it....................
    1 play your video in VideoRidePlayer after opening Tuning Center in Game Engine,
    2 capture Max and Min of your Telemetry data in Tuning center
    3 save those Max and Min in Tuning Center.
    You are now able to read the video and move the simulator simultaneously.
    the cat is very happy now :grin
  4. accelero
    accelero Member
    france
    189Coins
    Hi guys I have found an app that can record a video plus its related accelerometer and gyro data from my smart phone .
    I tried to create a video in Video ride creator to play it on Simmtools and move my platform.
    Unfortunatly i got a message that is not very clear to me. Capture d’écran (34).png
    any advice?
  5. accelero
    accelero Member
    france
    189Coins
    Its in french but means
    Conversion from string "0.0900098" ( which is one of the data ) to double is not valid ......... bla bla bla bla
    152,535Coins
    +11,085 / 56 / -2
  7. accelero
    accelero Member
    france
    189Coins
    Thank you Noorbeast that is all right :thumbs
  8. vallois
    vallois New Member Gold Contributor
    - 17Coins
    it's cool but you also need the plugin. I can not launch the video player?????
    hello is there a video tutorial of the video recorder and the use of a film for example.
    it would be great to have a video link
    152,535Coins
    +11,085 / 56 / -2
    The SimTools v2 - Video Ride Creator is a Companion App, which means it requires SimTools Professional License to use it: https://simtools.us/licenses/
    It is possible to upgrade from the DIY to Pro SimTools license by logging into SimTools.us. There you will find an upgrade path for a DIY license to Pro for $29.99.
    I am not aware of a video, but instructions are in the first post: https://www.xsimulator.net/community/threads/simtools-v2-video-ride-creator.9897/
  10. vallois
    - 17Coins
    hello, i need help i have an error message when starting video ride creator. my pc is up to date, framework, visual studio,...
    152,535Coins
    +11,085 / 56 / -2
    Can yo please expand the Details button of that error message, then copy and past the full error here.
  12. vallois
    - 17Coins
    the message says.
    Unhandled exception has occurred in your application. If you click Continue. the application will ignore this error and attempt to continue. If you click quit, the application will close immediately.
    An error occurred creating the from. See Exception . InnerException for details. The error is : Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
  13. vallois
    - 17Coins
    System.InvalidOperationException: An error occurred creating the form. See Exception.InnerException for details. The error is: Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)) ---> System.Runtime.InteropServices.COMException: Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))
    at System.Windows.Forms.UnsafeNativeMethods.CoCreateInstance(Guid& clsid, Object punkOuter, Int32 context, Guid& iid)
    at System.Windows.Forms.AxHost.CreateWithLicense(String license, Guid clsid)
    at System.Windows.Forms.AxHost.CreateInstanceCore(Guid clsid)
    at System.Windows.Forms.AxHost.CreateInstance()
    at System.Windows.Forms.AxHost.GetOcxCreate()
    at System.Windows.Forms.AxHost.TransitionUpTo(Int32 state)
    at System.Windows.Forms.AxHost.CreateHandle()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.AxHost.EndInit()
    at VideoRideCreator.frmPlayer.InitializeComponent()
    at VideoRideCreator.frmPlayer..ctor()
    --- End of inner exception stack trace ---
    at VideoRideCreator.My.MyProject.MyForms.Create__Instance__[T](T Instance)
    at VideoRideCreator.frmMain.pnl_Close_Click(Object sender, EventArgs e)
    at System.Windows.Forms.Control.OnClick(EventArgs e)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.9037.0 built by: NET481REL1
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
    VideoRideCreator
    Assembly Version: 0.2.1.0
    Win32 Version: 0.2.1.0
    CodeBase: file:///C:/Program%20Files%20(x86)/VideoRideCreator/VideoRideCreator.exe
    ciqscyGSQjQUQejDxPhWCOSaRKI
    Assembly Version: 0.0.0.0
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.8.9037.0 built by: NET481REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    System.Windows.Forms.DataVisualization
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.DataVisualization/v4.0_4.0.0.0__31bf3856ad364e35/System.Windows.Forms.DataVisualization.dll
    Accessibility
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    AxInterop.WMPLib
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/VideoRideCreator/AxInterop.WMPLib.DLL
    Interop.WMPLib
    CodeBase: file:///C:/Program%20Files%20(x86)/VideoRideCreator/Interop.WMPLib.DLL
    System.Data
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
    enabled.
    For example:
    <configuration>
    </configuration>
  14. yobuddy
    51,181Coins
    Permission problem maybe?
    Try running the app as admin.
  15. vallois
    - 17Coins
    I put everything in U.S English, the time synchronize U.S
    . and the exe in admin. I still have the error.
  16. yobuddy
    51,181Coins
    Unfortunately the error code '0x80040154' is a pretty general problem code, and there is not a lot to go on here.
    It may be worth white listing VRC just to be sure its not antivirus interfering.
    What antivirus are you running buddy?
  17. vallois
    - 17Coins
    so I have no antivirus.
    I use cclean or adw cleener that's all.
    i will try on another pc
  18. accelero
    accelero Member
    france
    189Coins
    a feedback on my use of VRC:
    The attempt consists in filming with a smartphone onboard a vehicle and getting from the smartphone the telemetry data synchronized with the video
    uploading everything on a PC
    then open the video file with VRC that writes an empty telemetry file
    then get from the smartphone csv files containing telemetry data and copy and paste the data in the empty cfg file attached to the video
    then open the video file in VRP
    the result is a moving platform according to the data, this result is great.
    I still have a lot of work to tune the different "dof" in order to have on the platform a similar feeling to the one aboard the vehicle.
  19. yobuddy
    51,181Coins
    Thanks for the feedback on VRC.
    I will hopefully have an easier way to make ride films in the future.
    https://www.xsimulator.net/communit...ers-fixes-show-tell.16962/page-12#post-228395
    Would be so cool to be able to make and share diy ride films from around the world. :thumbs
    Know that you can 'import' the data from the csv file into the empty telemetry file also.
    (So you don't have to do it by hand is all.)
    Take care!
  20. accelero
    accelero Member
    france
    189Coins
