Question First run 2DOF platform. Can you help?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Deeppl, Sep 1, 2021.
Tags:
  1. Deeppl
    Deeppl Member
    277Coins
    2DOF, DC motor, Motion platform
    Hi.
    My machine started. It is amazing.
    So far only a video from work because I could not wait.
    Specifications, problems and solutions soon.
    Best regards to all interested.
    152,247Coins
    +11,066 / 56 / -2
  3. Deeppl
    Deeppl Member
    277Coins
    I only used the roll and pitch axes.
    Should I add a Sway axis too?
    Same as roll but reverse the direction of the motors?
    I understand well
  4. Deeppl
    Deeppl Member
    277Coins
    It actually looks like this.
  5. Deeppl
    Deeppl Member
    277Coins
    Specification:
    Arduino UNO with SMC3 in mode1
    Cytron MD13S
    220W 24V wheelchair motors (approx 100 rpm)
    2x DPS-800GB power supplies modified for 24V
    152,247Coins
    +11,066 / 56 / -2
    Even on a 2DOF to get the full benefit you should configure sway, simulated heave and surge, as well as roll and pitch.
    See the tuning tips here and initially do each axis individually, then turn them all on for final tweaking: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    You can go a bit over 100% total axis allocation, but don't overdo it: https://www.xsimulator.net/community/faq/axis-assignment-percentage-totals.120/
  7. Deeppl
    Deeppl Member
    277Coins
    Hi. After your advice, I improved the operation of my machine. It is incomparably better;) Thanks.
    See the changes I have made and say what you think.
    These are pictures of the current axis settings:
    I am waiting for further advice.
    Regards.
  8. Deeppl
    Deeppl Member
    277Coins
    Some history. My first smc3 test circuit. I connected the uno with the citron drivers along with the 12v wiper motors. Potentiometers not connected to the motor shaft but it was enough for the first test;)
    this is my first contact with arduino
  9. Deeppl
    Deeppl Member
    277Coins
    I have a problem with the configuration of the 3rd engine.
    After adding [C <Axis3a>] all communication starts to lag. Latency appears to increase over time and is counted in seconds, not ms.
    152,247Coins
    +11,066 / 56 / -2
    You would normally set up SMC3 as Serial, like this:
  11. Deeppl
    Deeppl Member
    277Coins
    I use a second computer for quick adjustments. Therefore, UDP is the only way. I guess.
    152,247Coins
    +11,066 / 56 / -2
  13. Deeppl
    Deeppl Member
    277Coins
    It's very interesting. Thanks, I have to check it out. I did not think that you can change ON / OFF there. ;)
