  1. Manes
    Manes Member
    179Coins
  2. Manes
    Manes Member
    179Coins
  3. Manes
    Manes Member
    179Coins
    Is posible Sabertooth 2x60 is very Big for my motors? Is better 2x32 for my?
  4. Manes
    Manes Member
    179Coins
    My power supply have 28 V. Maybe is this the problem?
  5. John Snell
    John Snell Member
    192Coins
    Hi team. I'm missing something here and assume it will be obvious to many/most of you so my apologies if I should have found the answer already.
    I have 2 motors supplied via an Arduino and H-bridges. I have followed SMC3 tutorials the best I can, and everything seems to work fine using SimTools_2.5.1.exe.
    I have installed Live for Speed, run it, patched it, and I can see all the feedback and movement from the game in the SimTools Game Engine Virtual Axis display. BUT nothing makes my motors move
    In SimTools:
    - I believe I have set Interface settings (Interface 1) to match tutorials and with ComPort the same as in SimTools_2.5.1.exe.
    - I've set some values for (a) and (b) in Axis Assignments using Generis 2D Basic. settings the Game manager says that the game is connected
    - In output Testing=>Axis Testing=>Output Type = DOF Output, I "Turn On" and then move sliders for Roll, Pitch, etc. If I "Turn On" in the Virtual Axis tab I can see my "Axis Testing reflected there.
    BUT still nothing (apart from imTools_2.5.1.exe) will make my motors move.
    I appreciate any help greatly.
    John
  6. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    2DOF, DC motor, SimforceGT
    hello friend in the smc3 they work well with the preset movements if there is everything works well you can go to the configuration of the game engine of simtools. Now I am going to upload a configuration for you to copy and test.
  7. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    In the second photo it puts the configurations in axis1 and axis2 because axis3 and axis4 would be for the third and fourth motor and if surge and sway do not give you movements, try pitch and roll. 20210905_203932.jpg 20210905_204002.jpg
    153,703Coins
    If Output Testing works as expected then the likely issue is that LFS was not run prior to patching it for motion: https://www.xsimulator.net/communit...run-in-first-person-mode-before-patching.365/
    If so then un-patch LFS in Game Manager, run a LFS race in first person mode then re-patch LFS.
  9. John Snell
    John Snell Member
    192Coins
    Thank you so much @moaale. That's really kind of you to post these settings so fast!
    I have replicated them exactly, and also tried pitch and roll, but unfortunately there is no change. It feels like there is something missing between Simtools and the Arduino. They are just not communicating.
    When I start SMC3Utils v1.01.exe, there is often a small movement in the motors, and then while it is running there is a very quiet rumble coming from the motors. But there is nothing once I close SMC3Utils v1.01.exe.
    Am I correct that if I turn on Output Testing=>Axis Testing and then move the sliders, my motors should move in response?
    Thanks again!
  10. John Snell
    John Snell Member
    192Coins
    Hi @noorbeast
    I think Output Testing, or even Output in general, is where my issues lies (but happy to be corrected though), and maybe my expectations are incorrect. Output Testing currently does nothing at all, with regards to my motors. If I turn on Output Testing=>Axis Testing On, and then move the sliders, should my motors should move in response?
    I certainly see all the movement from LFS in Simtools Virtual Axis dashboard (see screenshot) when running LFS, so does that indicate that the game is correctly communicating with Simtools and the issue lies elsewhere, from Simtools to the Arduino?
    Thank you very much noorbeast
      140 KB
      345
    153,703Coins
    Do you have a Default profile configured in Axis Assignments, as that is what Output Testing uses?
  12. John Snell
    John Snell Member
    192Coins
    That's definitely good information to keep in mind, but yes I have it set to Default profile.
    I've tried, unsuccessfully, turning off the Windows firewall in case it's blocking traffic from SimTools, but not from the SMC3 test util.
    Next plan is to uninstall/re-install Simtools, and if no luck then set it all up on another PC.
  13. noorbeast
    153,703Coins
    Just checking you are not running SimTools and SMC3 at the same time, as that will create a port conflict.
  14. John Snell
    John Snell Member
    192Coins
    Solved!! I installed Simtools and LFS on another machine and it worked immediately!! Too easy considering how long I spent thinking I was missing something important and just didn't understand :-(
    Thanks to @noorbeast and @moaale, I realised that I wasn't far off, and to persevere. Thanks guys!
    Next step, is starting the full build.
  15. Chris_Beeves
    2,164Coins
    Hey people!
    I’m struggling a bit with some stubborn Escon motor drivers. They say they want up to 5kHz PWM, and when I drive them with a simple sketch with 3.9kHz PWM they always work. However, when setting 5kHz in smc3 windows utility I get lots of errors and cut outs. I’d like to change the frequency in the arduino sketch, but how do I do that without having the utility overwriting it when I run it?
    Have a good one!
    /Chris
  16. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,035Coins
    3DOF, DC motor, Arduino, 6DOF
    No, the sabertooth can take from 6 to 30 V. And it is not too big. I run small motors on it. Maybe your sabertooth is defective?
  17. Manes
    Manes Member
    179Coins
    Maybe.... I go to try with a 2x32... A friend have one and he go to lend this days... Keep on touch. You Will have news this days....
  18. Chris_Beeves
    2,164Coins
    A little bit of a lifter here, but I haven't gotten around the encoder issues until very recently.
    In utils you can only set as low as 5kHz, I need the PWM frequency to be 3.9kHz and from what I can see in the arduino sketch that seems doable, I just can't figure out where to put it. And will not Utils change it back when I run it again?`
    Cheers!
  19. Manes
    Manes Member
    179Coins
    Is necessary to put resistors between the motors and Sabertooth??
  20. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,035Coins
    No, I had only a relay, on or off.
