F1 2021 2021-09-08
SimTools plugin for Codemasters F1 2021
  1. yobuddy
    51,229Coins
    yobuddy submitted a new resource:
    F1 2012 - SimTools plugin for Codemasters F1 2021
  2. bruno1210
    bruno1210 schumi06
    103Coins
    if the plugin is made on 2018 ou 2021 telemetry schema? thank
  3. yobuddy
    51,229Coins
    It patches and run's with 2018 for this release, if your asking me that buddy?
  4. bruno1210
    bruno1210 schumi06
    103Coins
    your plugin is very good but I replayed f1 2020 and the effects were much stronger can you make the same settings in the f1 2021 plugin or tell me the software you need to modify it thank you .
    152,640Coins
    +11,087 / 56 / -2
  6. Martin.Berger
    Martin.Berger Member
    216Coins
    152,640Coins
    +11,087 / 56 / -2
  8. Martin.Berger
    216Coins
    Hi Noorbeast,
    plugin is in the correct Folder c:\***\MyGames\F1_2021
    the settings of hardwaresettings.xml are:
    <motion>
    <dbox enabled="false" />
    <udp enabled="true" broadcast="true" ip="127.0.0.1" port="20777" sendRate="60" format="2021" yourTelemetry="public" />
    </motion>
    Did i forget enything?
    Thank you
  9. yobuddy
    51,229Coins
    Hi @Martin.Berger,
    Looks like your editing the hardwaresettings.xml file by hand?
    I only ask, as these are not the settings the plugin patches with is all.
    Please remove the patch, then complete one race in the game, then exit the game and re-patch it.
    Let me know how it goes.
  10. bruno1210
    bruno1210 schumi06
    103Coins
    2021 ? no 2018
  11. bruno1210
    bruno1210 schumi06
    103Coins
    port 2021 ? 2018 yes
  12. Martin.Berger
    216Coins
    >Hi Guys
    My Game engine showed me the following error:
    There is no reliable data from the game.
    Numers just flickering arround
    Hope you can help
    Thamks maritn
  13. noorbeast
    152,640Coins
    +11,087 / 56 / -2
    Expand the Details in the error and copy then paste the full error here.
    Is the game patched to the correct path for your Windows version: https://www.xsimulator.net/communit...-32-bit-install-path-for-motion-patching.260/
    Is your computer set to English Local: https://www.xsimulator.net/community/faq/simtools-language-setting-bug-change-to-english-local.233/
  14. Martin.Berger
    216Coins
    Hi
    1st yes.
    2nd no
    Were there any changes. in 2020 everything worked fine?
    I´m a bit confused: during the patching is says patch to 2020?! Is this correct?
    I tested both 2020 and 2021 nothing works fine.
    Tuning center gives strange gamedata. there are just fo milliseconds some numers
    Motors flickering arround
    in lfs everything works fine
    152,640Coins
    +11,087 / 56 / -2
    Try changing to English Local and see if that makes a difference, as it is an intermittent but known bug.
  16. Martin.Berger
    216Coins
    Hello again,
    I got the error again today. Here is te full text:
    System.OverflowException: Arithmetic operation resulted in an overflow.
    at SimTools_GameEngine.frm_GameEngine.tmr_VirtualAxes_Tick(Object sender, EventArgs e)
    at System.Windows.Forms.Timer.OnTick(EventArgs e)
    at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4420.0 built by: NET48REL1LAST_C
    SimTools_GameEngine
    Assembly Version: 0.2.5.1
    Win32 Version: 0.2.5.1
    CodeBase: file:///E:/SimTools/SimTools/SimTools/SimTools_GameEngine.exe
    XuDYjHvzySWkLCvzNJOypnienfi
    Assembly Version: 0.0.0.0
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    Win32 Version: 4.8.4360.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    Win32 Version: 4.8.4390.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    Win32 Version: 4.8.4400.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    Win32 Version: 4.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    Log
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///E:/SimTools/SimTools/SimTools/Log.DLL
    System.Windows.Forms.resources
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.Windows.Forms.resources.dll
    System.Management
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    Microsoft.GeneratedCode
    Interface_PluginAPI
    CodeBase: file:///E:/SimTools/SimTools/SimTools/Interface_PluginAPI.DLL
    AMC_InterfacePlugin
    CodeBase: file:///C:/Users/Marti/AppData/Local/SimTools/GameEngine/InterfacePlugins/AMC_InterfacePlugin.dll
    HyperAXIS_InterfacePlugin
    CodeBase: file:///C:/Users/Marti/AppData/Local/SimTools/GameEngine/InterfacePlugins/HyperAXIS_InterfacePlugin.dll
    JRK_InterfacePlugin
    CodeBase: file:///C:/Users/Marti/AppData/Local/SimTools/GameEngine/InterfacePlugins/JRK_InterfacePlugin.dll
    Jrk
    Assembly Version: 1.1.0.1
    Win32 Version: 1.1.0.1
    CodeBase: file:///E:/SimTools/SimTools/SimTools/Jrk.DLL
    UsbWrapper
    Assembly Version: 1.5.1.0
    Win32 Version: 1.5.1
    CodeBase: file:///E:/SimTools/SimTools/SimTools/UsbWrapper.DLL
    MemoryMap_InterfacePlugin
    CodeBase: file:///C:/Users/Marti/AppData/Local/SimTools/GameEngine/InterfacePlugins/MemoryMap_InterfacePlugin.dll
    Network_InterfacePlugin
    CodeBase: file:///C:/Users/Marti/AppData/Local/SimTools/GameEngine/InterfacePlugins/Network_InterfacePlugin.dll
    SCN_InterfacePlugin
    CodeBase: file:///C:/Users/Marti/AppData/Local/SimTools/GameEngine/InterfacePlugins/SCN_InterfacePlugin.dll
    Serial_InterfacePlugin
    Assembly Version: 1.0.0.1
    Win32 Version: 1.0.0.1
    CodeBase: file:///C:/Users/Marti/AppData/Local/SimTools/GameEngine/InterfacePlugins/Serial_InterfacePlugin.dll
    AxisAssignments_PluginAPI
    CodeBase: file:///E:/SimTools/SimTools/SimTools/AxisAssignments_PluginAPI.DLL
    Generic2DAdvanced_AxisAssignmentsPlugin
    CodeBase: file:///C:/Users/Marti/AppData/Local/SimTools/GameEngine/AxisAssignmentsPlugins/Generic2DAdvanced_AxisAssignmentsPlugin.dll
    Generic2DBasic_AxisAssignmentsPlugin
    CodeBase: file:///C:/Users/Marti/AppData/Local/SimTools/GameEngine/AxisAssignmentsPlugins/Generic2DBasic_AxisAssignmentsPlugin.dll
    Generic2DStandard_AxisAssignmentsPlugin
    CodeBase: file:///C:/Users/Marti/AppData/Local/SimTools/GameEngine/AxisAssignmentsPlugins/Generic2DStandard_AxisAssignmentsPlugin.dll
    Default_InterfacePlugin
    CodeBase: file:///C:/Users/Marti/AppData/Local/SimTools/GameEngine/InterfacePlugins/Default_InterfacePlugin.dll
    Default_AxisAssignmentsPlugin
    CodeBase: file:///C:/Users/Marti/AppData/Local/SimTools/GameEngine/AxisAssignmentsPlugins/Default_AxisAssignmentsPlugin.dll
    Game_PluginAPI
    CodeBase: file:///E:/SimTools/SimTools/SimTools/Game_PluginAPI.DLL
    F1_2019_GamePlugin
    Assembly Version: 2.0.1.0
    Win32 Version: 2.0.1.0
    CodeBase: file:///C:/Users/Marti/AppData/Local/SimTools/GamePlugins/F1_2019_GamePlugin.dll
    F1_2020_GamePlugin
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.0.0
    CodeBase: file:///C:/Users/Marti/AppData/Local/SimTools/GamePlugins/F1_2020_GamePlugin.dll
    F1_2021_GamePlugin
    CodeBase: file:///C:/Users/Marti/AppData/Local/SimTools/GamePlugins/F1_2021_GamePlugin.dll
    LiveForSpeed_GamePlugin
    Assembly Version: 2.1.0.0
    Win32 Version: 2.1.0.0
    CodeBase: file:///C:/Users/Marti/AppData/Local/SimTools/GamePlugins/LiveForSpeed_GamePlugin.dll
    enabled.
    For example:
    <configuration>
    </configuration>
    Any ideas?
    I got movement at all after doing one race unpatched and repatch f1 2021.
    BUT: movement ist strange: just on Heacve
    Not on Roll Pitchh and so on.
    Axias jumps arround silly.
    Changing settings in Telemetry-Menue doesnt change anything
    Hope anyone has an idea?
    Thanks Martin
    152,640Coins
    +11,087 / 56 / -2
    You have some really strange Tuning Center values, so try clicking capture max/min, reset all, drive for a while without hitting anything, back in Tuning Center save then finally stop capture. That should give you a base Tuning Center configuration, which you can then configure to refine it.
  18. bruno1210
    bruno1210 schumi06
    103Coins
  19. danone38
    danone38 New Member
    - 291Coins
    hello i can't run simtools and simhub at the same time, when i use udp 2018, simtools is ok but not simhub, when i use udp 2021 simhub is ok but not simtools
    152,640Coins
    +11,087 / 56 / -2
