Question Need Help with Pololu Vnh5019
Discussion in 'Ready, set, go - Start your engines' started by TheLittleGnome, Jun 15, 2020.
  1. TheLittleGnome
    TheLittleGnome New Member
    33Coins
    does anyone drive a 2DOF with an Arduino and pololu Vnh5019 driver? Need help with the code, probably the pin assignment.
    152,247Coins
    +11,066 / 56 / -2
  3. TheLittleGnome
    33Coins
    152,247Coins
    +11,066 / 56 / -2
    That thread covered the connections and limitation of the vnh5019.
    You likely need to be more specific of what you have and have not done, using what hardware and code. That way the likes of @Pit may be able to give specific advice.
  5. Pit
    30,491Coins
    The VNH5019 is quite easy to configure and works as long not too much power is needed (as @noorbeast mentioned, the VNH5019 show some limitations). Anyway if you want any help I need more information about your settings, hardware, wiring etc.
  6. Yooorglh
    Yooorglh New Member
    7Coins
    I'm using VNH5019 too. i did follow the https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
    especially the use of the SMC3 Utils. i get the motor to turn, driving the pot and stopping nicely ! but... there is always a but. it doesn't turn in reverse (using the "motion" option).
    i tested the motor alone and it can turn in both direction.
    i tested being on M2 config (changing the wiring of course)... Same,
    i'm using the SMC3.ino stock. Zero change in it as VNH5019 has same pin numbering (according arduino forum)
    Honestly, i did not read the 103ish pages... but i do search with "VNH5019" keyword without success...
    Anyone faced the same issue (even with a monster moto) ?
    Thanks for your help
    152,247Coins
    +11,066 / 56 / -2
    Are you using Wiper motors and if so are they ground isolated: https://www.xsimulator.net/community/faq/wiper-motor-mandatory-ground-isolation.25/
  8. Yooorglh
    Yooorglh New Member
    7Coins
    thanks for helping, yes, i checked with the multimeter. it is a one speed and 2 wire only for testing purpose.
    btween ground and each wire there is no "bip" ^^'
    i took some picture. maybe it will help.
    152,247Coins
    +11,066 / 56 / -2
    Just to clarify, has the wiper motor been pulled apart and ground isolated: https://www.xsimulator.net/community/faq/wiper-motor-mandatory-ground-isolation.25/
    See this video from about 6 minutes in for a visual explanation:
  10. Yooorglh
    Yooorglh New Member
    7Coins
    sooo. i rechecked :p
    no issue on the motor. I expected it was the pot because when it should go backward, the led should light up but it was not the case. replaced and same happen... now i'm thinking maybe it is the Vnh5019. So i ordered another one.
    I'll change the arduino and cable to see if something change...
    I'll keep you posted ^^
    PS : nice compact sim build !! plenty of idea to grab !!
  11. Yooorglh
    Yooorglh New Member
    7Coins
    hum...
    it seems that the black connector are not connected the driver... I fixed the cable as shown on the picture (instead of where it should be at the red cross) and it works !!!
    what a s..t it was supposed to be directly connected on an Arduino without any cable and it is even worth...
    thanks @noorbeast to have supported me anyway !
    next : make it work with Simtools !
  12. Yooorglh
    Yooorglh New Member
    7Coins
    Everything works. is it possible to update the 1st post warning that the pin numbering of the SMC3 is not fully matching the internal trace of the VNH5019 so it is not stackable.
    I don't know if only changing the Pin numbering at the beggining of the .ino file is good enought
    in attachement the pin matching in green / not matching in red
    sorry for my English, i'm french :p
