Cant Afford a Motion Rig. But I Studied the Dof Reality
Discussion in 'DIY Motion Simulator Projects' started by coy, Sep 21, 2021.
  1. coy
    coy New Member
    39Coins
    I Found Parts Far Superior to the H3 Motors. Actual 40nm Steel Geared Worm Gear Servos. So I Am Just Going to Convert My Gt Omega Chassis Into a 3 Dof Rig... I Will Need Help With the Software in the Future. If You Dont Want to Go Through the Extra Trouble of Addind Encoders to Wiper Motors, Here Is a Link for the Servos.. On $175 Each.. https://www.amequipment.com/shop/hd40-industrial-servomotor
  2. superwhitewish
    superwhitewish Member
    Avionic Engineer
    Malaysia
    225Coins
    Other important things that you need to find out about the motor are rated torque and rated speed. 40NM mentioned is the stall torque which is not the correct indication of the ability of the motor. Also 520 pulse per revolution at the output shaft is quite low imo and you cannot use the smc3 with encoder, only potentiometer or hall sensor.
