[Solved] Arduino code with seperate Gap
Discussion in 'SimTools compatible interfaces' started by Blekkulf, Sep 29, 2021.
  1. Blekkulf
    Blekkulf Member Gold Contributor
    Molde
    342Coins
    2DOF, AC motor, Arduino, Joyrider, 6DOF
    Hello!
    Im using VFD's on my sim, and I control speed by triggering two digital inputs with 00 - 01 - 10 - 11 to have four preset speeds. I use relays and use Gap in the code to trigger the different speeds. Problem is that i need two different Gaps.
    if (gap1>50) digitalWrite(42, HIGH)
    if (gap1>75) digitalWrite(43, HIGH)
    if (gap1>100) digitalWrite(44, HIGH)
    if (gap2>50) digitalWrite(45, HIGH)
    if (gap2>75) digitalWrite(46, HIGH)
    if (gap2>100)digitalWrite(47, HIGH)
    The orginal code is like this;
    int gap;
    int pwm;
    int brakingDistance=30;
    targetPos=constrain(targetPos,potMini+brakingDistance,potMaxi-brakingDistance);
    gap=abs(targetPos-actualPos);
    if (gap<= Tol) {
    motorOff(numMot); //too near to move
    else {
    // PID : calculate speed proportionaly to distance to go
    pwm=195;
    if (gap>50) pwm=215;
    if (gap>75) pwm=235;
    if (gap>100) pwm=255;
    guess i need targetPos1 and 2, and actualPos 1 and 2 too then.
    any good suggestions ? :)
  2. Zed
    USA
    5,841Coins
    If I understand what you are doing, you do need separate variables to hold the different values. A single variable can only hold one value at a time.
    There are “exceptions” where you encode information in individual bits or in upper or lower nibbles, array elements, etc, but it’s still really just one variable, one value.
  3. Blekkulf
    Molde
    342Coins
    Thanks for the reply! Yeah, instead of Gap, I need Gap1 and Gap2 to get two variables. But I think its easier to just double the arduinos, so I have one arduino on each motor :)
  4. Blekkulf
    Molde
    342Coins
    I cant get this digital outputs to change. I got serial.print on "gap", so i know it changes without triggering the outputs. The outputs change if i change the status of the speedpin 1 and 2 in the void setup.
    if (gap<= Tol) {
    else {
    // PID : calculates speed according to distance
    if (gap>50) digitalWrite(speedpin1=LOW,speedpin2=LOW);
    if (gap>75) digitalWrite(speedpin1=LOW,speedpin2=HIGH);
    if (gap>100) digitalWrite(speedpin1=HIGH,speedpin2=LOW);
    if (gap>200) digitalWrite(speedpin1=HIGH,speedpin2=HIGH);
    // if motor is outside from the range, send motor back to the limit !
    // go forward (up)
    if ((actualPos<potMini) || (actualPos<targetPos)) motorGo(numMot, FW, pwm);
    // go reverse (down)
    if ((actualPos>potMaxi) || (actualPos>targetPos)) motorGo(numMot, RV, pwm);
  5. Blekkulf
    Molde
    342Coins
    Solved! Changed the digitalWrite to two seperate lines and changed from = to , .
  6. Zed
    USA
    5,841Coins
    Glad you got it working. Just a comment on that code snippet though, if gap is 201 or more, every if statement will get executed because they would all be true. That may not matter to the actual functioning, but those speed pins will flutter in state each time that code executes unless gap is 50 or below where only one if gets executed. I’d recommend looking at a switch/case statement or if/else.
  7. Blekkulf
    Molde
    342Coins
    Yeah I know. I put the 200 on top and 50 on bottom.. seem to work:) thanks anyway :thumbs
  8. Zed
    USA
    5,841Coins
    That arrangement might cause issues though. Executing in the reverse sequence can let the lower gap values take over. Again, if the gap value was 201, they would all still all be true but the last command to execute in that sequence would be the one with gap value greater than 50 and would leave the speedpins both low instead of high.
  9. Blekkulf
    Molde
    342Coins
    Hmm.. seems like it goes down to the one thats True, and then starts from the top again.. i dont get any signals from 150, 75 or 50 when its 201.
  10. Zed
    USA
    5,841Coins
    Just going by the code you posted, with gap equal to 201, since all the statements would be true, the last one to be evaluated would be the assignment you’re left with with either ordering using just if statements. Maybe your code is now different from what I’m commenting on but unless I’m missing something, I believe that’s how it would work. It may not matter to how you use the speed pins but I don’t know.
