X-Sim and Windows 7 64Bit
Discussion in 'New users start here - FAQ' started by V8gina, Feb 16, 2010.
  1. V8gina
    V8gina New Member
    0Coins
    Hi Guys,
    I've been doing a fair bit of reading and have convinced myself I need to pursue building a 2DOF Simulator. At this stage I'm planning on following the steps from Master Yoda on converting a Frex style Simulator to X-Sim. how-to-convert-your-frex-scm-to-x-sim-t1412.html .
    I haven't purchased any parts yet, but before I do I wanted to clarify my concerns with Win 7 64Bit not being supported by X-sim as all my games etc... will be running on a 64 bit machine.
    What i wanted to know is:
    1. Can i run my games (rfactor mostly) on my Win 7 64 Bit machine, and run the X-Sim software on my 2nd Win 7 32 Bit machine ?
    OR
    2. To utilise X-Sim do I need to have both PC's running 32 Bit ? If this is the case I'm probably better off just running on a single PC as I have a fairly high end I7 PC with plenty of power.
    Thanks in advance for any advise, I just really wanted to avoid running my games on a 32 bit system after spending good money on my newish Window 7 64 bit system.
    Gina.
  2. RaceRay
    Hamburg, Germany
    23,884Coins
    Hi V8gina,
    i use all my games (dirt2, rfactor, lfs, etc. )without any problems on my windows 7 64bit system. Also the new beta version of the x-sim software viewtopic.php?f=1&t=2150 works on the same dual core system like a charm. So i suggest to give it a try.
    It´s not nessecary to use a second pc, but it is very comfortable to control the actuators when you use a second pc. For example, you are driving and a friend is is able to control the actuators during gameplay at the same time without interupting the game. That´s a good way to find your personal best fitting settings.
    Btw. Gina sounds like a female name! When that´s true, you are the first woman here. At least the only one i know ;)
    regards
    René
  3. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    422Coins
  4. V8gina
    V8gina New Member
    0Coins
    Thanks Rene for the confirmation. Makes my decision on making the investment much easier.
    Sorry to dissapoint, V8gina is my screen name, no ladies yet im afraid.
    But my mates often think I drive like a woman :)
  5. Frakk
    Frakk Active Member
    328Coins
    I am having issues with the Force Sender running on Win7 32bit. The problem is that it doesn't get the values from the games. When I try the Test Plugin, everything works, the Profiler running on my laptop picks up these sliders no problem, but when I change the plugin for GTR2, all values are 0.
    Any suggestions?
  6. jmcinty1
    jmcinty1 New Member
    1Coins
    Make sure you enable Memory sharing in your .plr file. Look for:
    Write Shared Memory=1 // Write game data to shared memory area
    John (MadMac)
  7. Frakk
    Frakk Active Member
    328Coins
    It is enabled, that's why I cannot find out why it wouldn't work. :(
  8. Brightonuk
    Brightonuk Member
    Business Owner
    Plantation, FL
    492Coins
    :lol: LOL :lol:
  9. Fred Bear
    Fred Bear New Member
    Engineer
    148Coins
    Hello All.
    I just want to confirm simtools 2.x or v3 will run on a windows 7 pro pc ?
    Not a gaming pc, a win 7 pro desktop.... Games run on PS5.
    Many thanks
    Fred.
    153,710Coins
    As far as I am aware SimTools v2 will not run on XP, but should on later Windows machines, easy enough to install and check to be sure.
  11. Fred Bear
    Engineer
    148Coins
    Hello Noorbeast.
    Many thanks for your reply.
    I could not find any compatibility information in the user manual, or from searching.
    Simtools 2.6 runs in demo on my win 7 pro, although I have no drop-down available to select the DOF REALITY usb connection. I can select the com port.
    I will purchase a licence next to unlock and go from there.
    Have a good weekend.
    Fred
