Showroom DIY 2 DOF + traction loss + belt tensioner + Active pedal (Racecab style)
Discussion in 'DIY Motion Simulator Projects' started by hoyang, Mar 11, 2018.
  1. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
    I will make a diagram to make it more explicit
    153,986Coins
    +11,162 / 57 / -2
    Great to see you got it moving :thumbs
    It appears as though the motor mount and base are flexing, which will mask some of the motion cues. Adding some rigidity would help.
  3. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
    quick question, can the dead zone option of smc3 cause a delay on the motor tracking line?
    153,986Coins
    +11,162 / 57 / -2
    From the SMC3 instructions: https://www.xsimulator.net/communit...driver-and-windows-utilities.4957/#post-48121
    Deadzone This creates a hysteresis zone for the motor feedback If you need values greater than 1, you probably have too much “slack” in your mechanical setup.
    So in a sense yes, a dead zone will cause some delay, as its purpose is to filter signals so that the output reacts less rapidly than it otherwise would by taking recent system history into account.
  5. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,043Coins
    3DOF, DC motor, Arduino, 6DOF
    Unless someone will use it, why should you bother to make the diagram? I won't for sure. Way too complicated for me.
  6. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
    how i can do to properly adjust my pwm 0-10v converter.
    Screenshot_20211007-130105_Amazon Shopping.jpg Screenshot_20211007-130112_Amazon Shopping.jpg
  7. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
    problem solved !!
    my concern is due to a bad frequency setting of smc3Utils once passed to 5khz the speed variation has started to work correctly, I still have some overshoots on my tracking line, check if I can adjust this with the other parameters.
  8. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
    small overview of the bldc engine modify:
  9. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
  10. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
    modification of my bucket seat to add a 4-point belt with tensioner reel
  11. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
    home made 4 point belt and stepper motor for my belt tensioner
  12. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
    I find myself stuck with my communication on game engine. My arduino must receive a serial M1 800
    or M2 800 (800 has 0 being the position of my axis)
    I tried
    M1 <Axis4a> M2 <Axis5a>
    19200 baud rate
    8 bit data
    party none
    stop bit 1
    decimal
  13. John Snell
    John Snell Member
    192Coins
    Hi Hoyang. Have you made progress with this issue? I'm happy to try and help and maybe test things on my system, if I can, but I don't quite understand the description of the problem.
  14. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
    Je me rends compte que mon message précédent n'est pas du tout précis.
    ici, je crée un tendeur de courroie inspiré du tension-R de pt-actuator.
    après plusieurs ajustements et modifications, le système fonctionne plutôt bien (2 moteurs pas à pas nema 23 2.4Nm, 2 contrôleurs tb6600, un arduino nano).
    le code fonctionne avec tendeur simhub mais il ne me convient pas (je préfère des simtools beaucoup plus précis et souples).
    J'ai créé un code hier pour récupérer sur le moniteur le retour de simtools (moteur de jeu) et je pense avoir trouvé mon erreur.
    Exemple d'envoi de simtool :
    {M1<Axe4a> Je reçois M1##}
    le ## étant la valeur 8 bits d'Axis4a entre 0 et 1023
    J'ai besoin de modifier le code pour lire correctement cette valeur 8 bits.
    c'est là que je suis bloqué, je ne vois pas comment traduire cette valeur de 8 bits en décimal pour obtenir 0 à 1023.
    J'espère le mettre bien expliqué.
  15. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
    here is my belt tensioner with surge and sway effect working under simtools. 20220702_174257.jpg 20220702_210251.jpg
  16. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
  17. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
    completion of the bucket seat finishes:
  18. HI_iam_new
    HI_iam_new 0dof
    128Coins
  19. John Snell
    John Snell Member
    192Coins
    I thought I was nearly finished my rig, but now I realise I need one of these :)
  20. hoyang
    hoyang handyman
    Bricoleur
    1,343Coins
    yes the noise you hear in the background is that of the nema motors, I am working on it to reduce the noise (the box is completely open).
