IBT-2 and arduino uno isssue
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by cyberxu, Oct 10, 2021.
  1. cyberxu
    cyberxu Member
    AME Planner
    Ontario, Canada
    516Coins
    Hello all,
    I am having issue with getting my motors turn on. I followed the SMC3 instruction, schematic for wiring up to IBT-2 with my Arduino. When I tested with multimeter, Arduino code (SMC3.ino) uploaded with Mode 2 selected. I have notice the green line on AMC utility software is on the bottom of the graft.
    I ve got power(12v) on IBT-2 but no power on M+ /M- terminal. I have check many times on the wiring ...everything hooked up exactly as it should be.
    Can someone please help, I have been stuck here for 3 days trying to figure it out...no joy!
  2. Gadget999
    12,072Coins
    Does the green line move when you turn the potentiometer ?
  3. cyberxu
    cyberxu Member
    AME Planner
    Ontario, Canada
    516Coins
    Hi, thanks for the quick respond...
    No... the Green line doesn't move when i turned my pot. Its stay on the top of the graft. or bottom if i swapped the positive and negative. very frustrated.
  4. Gadget999
    12,072Coins
    Check the pot is the correct voltage and resistance
  5. cyberxu
    cyberxu Member
    AME Planner
    Ontario, Canada
    516Coins
    this is the Pot I am using...I wonder if its a good one?
  6. cyberxu
    cyberxu Member
    AME Planner
    Ontario, Canada
    516Coins
    My Pot is made by:
    BOURNS
    PN is 3590S-2-103L
    RES 10K ohm +/-5%
  7. Ties
    Ties New Member
    - 8Coins
    1 = 5V 2
    1= 5v 2= V+ 3= gnd, 1= red 2 = yellow or green 3= black. Have you tried swapping wire 2 with 3?
  8. cyberxu
    cyberxu Member
    AME Planner
    Ontario, Canada
    516Coins
    Yes I have swapped. I also checked with multimeter. I am not sure this pot is good for SIM building. I found out it is multi turn potentiometer. not sure it will make any different?
  9. cyberxu
    cyberxu Member
    AME Planner
    Ontario, Canada
    516Coins
    I have resolved my issue...It turns out it is my Multi turns Potentiometer that isn't compatible. I had ordered this yesterday. Now we wait. ...AGAIN! Haha
  10. ZeGrundPilot
    ZeGrundPilot New Member
    USA
    85Coins
    You using Arduino analog port 0. Is the IBT Connected to the correct motor control set for motor 1, 2 vs. 3? The code tells you which PWM control pins on the Arduino control which motor. If you are getting a PWM signal and it is hitting pin 2 on the IBT, you should be good. I you want to follow the ways of the purple path if your POT is on A0.
  11. Boris Furtak
    Boris Furtak Member Gold Contributor
    160Coins
    Having the same problem Gadget999 my encoder are 24v green line moves but when I pull the wire it doesn't change on the smc3 utility...
  12. Gadget999
    12,072Coins
    The smc3 program is designed to work with potentiometers NOT encoders
  13. cyberxu
    cyberxu Member
    AME Planner
    Ontario, Canada
    516Coins
    hi,
    After I replaced my Pot, Everything is good to go. It turns out that i was using a multi-turns pot which is causing the problem and green line is not in the center or the chart.
    cheers!
  14. cyberxu
    cyberxu Member
    AME Planner
    Ontario, Canada
    516Coins
    I just received my new worm gear motors today. it comes with stepper motor. I was wondering if anyone successfully uses these type of motors with IBT driver?
  15. Boris Furtak
    160Coins
    Cyberrxu... I'm sure it will work along as your supply is the same as the motors ... if you follow the steps on the smc3 forum ... I'm sure you will get some sort of movement on any DC motor how it will respond I'm not sure ....
  16. yondwangmms
    yondwangmms Member
    - 148Coins
    IBT can't drive stepper motor, I think your idea can't be realized with SMC.
  17. cyberxu
    cyberxu Member
    AME Planner
    Ontario, Canada
    516Coins
    Yeah, thanks for the respond. I realized that after i read on the forum...I need to use stepper motor driver in order to run these motors. I will also need some code for it too.
  18. cyberxu
    cyberxu Member
    AME Planner
    Ontario, Canada
    516Coins
    Ok Guys, I have been working on my controller box to fit IBT-2 and Arduino. Here are some of my pictures... Hope you guys like it.
    Using my son's Left over Lego for mounting IBT-2
    Utilizing my 3D printer to attach connectors
    Adding RGB Fan for Cooling....why not!!
    Back side of the box, Uno connection and 12v power with E stop.
