Question Help me please, What's Wrong with my SMC3 settings?
Discussion in 'News' started by Arta Yasa, Oct 13, 2021.
Tags:
  1. Arta Yasa
    Arta Yasa Member
    968Coins
    I have replaced the wiper motor with a 250watt wheelchair motor. I connect the pot with a pulley 50teeth and 30teeth (1 : 1.6 ratio) the settings I use are the same as the wiper motor. but why does it seem like the motor always shuts down (whether it shutdown bts7960 or from the smc3 program because it reads more pots) what are the characteristics if the potentio is damaged?? btw I have never replaced the potentiometer. or i have to parallel bts 7960?? even though using a wiper motor everything is safe.
    153,986Coins
    +11,162 / 57 / -2
    SMC3 settings should be made for specific hardware, not just transferred. Go back and do the setting up procedure from scratch.
  3. Arta Yasa
    Arta Yasa Member
    968Coins
    Alright sir. But if the pot is broken it will make like that sir?
    153,986Coins
    +11,162 / 57 / -2
    You can use the feedback line in SMC3 to check the pot.
  5. Arta Yasa
    Arta Yasa Member
    968Coins
    Hi sir whats wrong with my setting, if the rig without me, the feedback same with target. But if i seat on rig, the feedback not same like a target sir. That is because ratio pulley for pot sir???
