New Concept Multi-Output Motion Platform Controller Board
Discussion in 'SimTools compatible interfaces' started by McController, Sep 20, 2021.
  1. McController
    McController M-PULSAR
    104Coins
    2DOF, 3DOF, DC motor, SimAxe, Motion platform, 4DOF, 6DOF
    Hi everyone,
    I'm a simulation enthusiast and I'm building a controller board for motion platforms on my own.
    Characteristics:
    Power supply +12/24V.
    High-performance 32bit MCU 120Mhz.
    Capability to handle up to 12 actuators (pulse/dir), up to 12 inputs, and up to 16 digital outputs (open collector).
    Two serials (one RS232 and one RS485) and one Ethernet port.
    Possibility to expand the functionality with exp. boards.
    Those who are interested can contact me in PVT even because the electronic shortage
  2. McController
    104Coins
    These are some pictures of my controller. For those are interested
  3. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,755Coins
    Hi @McController
    Wellcome to the community!
    Your controller board looks interesting! Pls. can you give us some more information, especially how to wire things, what motors/motor driver can be connected, which functions does the controller have? Can it comminicate with Simtools or the "mover interface" from @pmvcda,....
    Thanks a lot!
    Wickie
  4. Gadget999
    12,035Coins
    It looks neat
    How do you program it ?
  5. pmvcda
    15,394Coins
    Cool, give us more info/specs.
    Some connection examples/videos and how to control it by serial or UDP (Ethernet port?)
  6. McController
    104Coins
    Hi everyone,
    These are some specs of the board but, if you have some suggestions, they are welcome.
    Motion Card 1.0 Specifications:
    - Power supply +12/24 Vdc.
    - Up to 24 differential output.
    - Up to 12 optoisolated inputs 12/24V.
    - Emergency function capabilities.
    - Fast 100 Mb ethernet port.
    - 1 RS485 port
    - 1 RS232 port
    - OLED display
    - Support FlyPT mover
    - Support DIR/PULSE motor drive
    Motion Card 1.0 Features:
    - Serial or Ethernet interface
    - Very low latency <1 msec - 500 Khz max pulse rate
    - Software endstop
    - Spike filters
    - Parameter modification from PC software (coming soon)
    - auto home calibration (with endstop)
  7. McController
    104Coins
    Depends of the election shortage, we are ready technically ready to commercialize it but there isn't CPU on the market right now
  8. McController
    104Coins
    I will publish here the instructions when will be available
  9. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,755Coins
    Hi again @McController
    I am still not sure, whether I understood your controller correctly. So here I made a sketch how I understand the function and use of your controller:
    If you make it possible to connect a PC with SimTools or mover-interface running to an industrial motor controller, then I think you will open a new chapter in DIY-simbuilding!
    My wishlist:
    - usable also for software-noobs like me. So no need to study programming
    - support for different optional interfaces/protocols for industrial motor-controllers
    - Good and easy user interface
    - good manual
    - not tooooo expensive:grin
    Wickie
  10. McController
    104Coins
    I have thought that the board-to-driver ethernet connection is not an easy and flexible solution like DIR/PULSE or the analog (the board has also analog signals +-10V capabilities with an opportunity expansion board that will come soon).
    There is also a latency problem on protocols like the Modbus or similar (tested yet without good results).
    Answering your welcome advice:
    No programming skill need, the parameters are not much and will be available a graphics interface soon for the setup
    Will be available the customization input protocol in order to accept industrial systems inputs even though is not easy, need time to collect and implement all protocol where possible but is projected to use the board for industrial purpose
    This is on progress developing
    - good manual
    The goal is that the UI will be so intuitive that the manual should be a quick help in the software itself
    This is the first target of our job, We would like to stay under the 150$ better closest to 100$
  11. yobuddy
    50,994Coins
    Love seeing new hardware, good work @McController!
    Take care,
  12. Dschadu
    Dschadu Active Member
    1,936Coins
    Looks promising. Do you plan to make it open source?
  13. McController
    104Coins
    Hi Dschadu, your idea looks interesting just first would like to return from some expenses then we could consider to make the project open source
  14. Dschadu
    1,936Coins
    Open source does not mean no money :) Take a look at i.e. oDrive. Soft+Hardware is open source, but they still sell the PCB to a lot of customers.
    And you would be surprised how generous this community is when there is a donate button and if your product works for them.
  15. McController
    104Coins
    The last and definitive board's hardware. Now hard working on the firmware. The member
    "Marco Annunziata"
    are cooperating with us testing, giving feedbacks and suggestions. At the moment the basic firmware release seems working fine
  16. McController
    104Coins
    Controller board working demonstration
  17. zhai1987
    zhai1987 Member
    320Coins
    2DOF, 3DOF, AC motor
    Has the project updated anything interesting?
  18. Marco Annunziata
    889Coins
    Hello, the board works fine just we are working on the pc interface for the configuration
  19. JohnH
    JohnH New Member
    2Coins
    Did this project die, or? It looked promising.
  20. McController
    104Coins
    No it's not die, actually ready for the selling, now we are workingNo it's actually ready for the selling, now we are working on improving a the spike filter, will be much configurable, which for motion platform with high performance is very important for the safety on improving a the spike filter, will be much configurable, which for motion platform with high performance is very important for the safety and refine the pc interface
