SimTools does not turn the motor, video
Discussion in 'New users start here - FAQ' started by Shock, Oct 15, 2021.
  1. Shock
    Shock New Member
    0Coins
    What am I doing wrong?
    153,986Coins
    +11,162 / 57 / -2
    Next time please post pictures, it is much easier to see settings than a moving video.
    There seem to be spaces in the Interface settings, copy and paste this: [A<Axis1a>][B<Axis2a>][C<Axis3a>]
    Do not run SMC3 and SimTools at the same time, it will cause a port conflict.
    Of course the pot should be properly secured.
  3. Shock
    Shock New Member
    0Coins
    New Everything worked as soon as I removed the spaces between the characters, it turns out that you have a misspelle line on the forum that the newbie copies and does not get the desired result, correct.
      178.4 KB
      305
