value1
rFactor2 Plugin 2.0.4.0
SimTools game plugin for rFactor2
  1. noorbeast
    152,241Coins
    +11,066 / 56 / -2
    Grab a copy of the SimTools manual and keep it handy for reference: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    You need to patch the game for motion, and specify the correct path.
    You also need to have configured a profile in Axis Assignments of Game Engine.
    Before any of that you need to have a Default profile that is configured as SimTools expects: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
    And ensure your rig works in Output Testing.
  2. Boris Furtak
    Boris Furtak Member Gold Contributor
    160Coins
    Thank you please take a look screen shots ... is any of this correct appreciated 20211017_072257.jpg 20211017_072228.jpg 20211017_072138.jpg
    152,241Coins
    +11,066 / 56 / -2
    I can't tell much from those settings, as in the Interface Settings only 2 axis are configured, yet in Axis Assignments 3 axis are configured.
    Is your rig configured and behave as expected in Output Testing?
  4. Boris Furtak
    160Coins
    ill only be able to plug in to my rig tomorrow ... was working from home ... i only need to actuate on 2 lin actuators on to 2axsis ... my rig is not anywhere near to the the sims you guys are building the setup very crude and ruff ...
    152,241Coins
    +11,066 / 56 / -2
    No problem, it does not matter what the rig looks like, just that we step through configuration step by step.
    From the Interface Settings I am presuming SMC3 is being used, is that configured and working as expected as that needs to be sorted prior to messing with SimTools?
  6. Boris Furtak
    160Coins
    Noorbeast ... when u say smc3 Is that my com to my adruino interface ... if so yes that com is for my microcontroller.. the values buts per sec parity I copied from a setup I saw on YouTube.. thanks again Mate ... I've gone back to the beginning finally got game Manger and game Engine connected... should I have rf2 in the game section
    152,241Coins
    +11,066 / 56 / -2
    Lets take a step back for a moment, have you uploaded the SMC3 code to an Arduino, configured it and ensured the hardware responds as expected: http://www.xsimulator.net/community...3dof-motor-driver-and-windows-utilities.4957/
    For that matter what hardware is being used?
  8. Boris Furtak
    160Coins
    152,241Coins
    +11,066 / 56 / -2
    That is the first step, SimTools comes later.
    For now detail everything in your own build thread, so all information is in one place, that way members will have some context when giving advice.
  10. Boris Furtak
    160Coins
    thank you very much Noorbeast I WILL FOLLOW YOUR ADVICE really great site thanks again guys...... BEERS ON ME
  11. Boris Furtak
    160Coins
    :grin OK I ALMOST FEEL LIKE IM GOING IN THE RIGHT DIRECTION thank you this answered alot of questions BRILLANT . I UPLODED THAT CODE TO THE UNO ITS ALSO HELPED ME UNDERSTAND THE WIRRING UP AND PINOUTS ......
  12. Evan Rowlands
    Evan Rowlands EMR Industries
    Melbourne Australia
    - 82Coins
    Gday everyone..
    I have an issue with installing the plug in.. I can't find where I need to patch it..ive tried the normal way
    D: D drive
    Steam
    Steam apps
    Content
    But no luck
    I've tried
    C: drive
    Program files 86
    Games
    But there is no R Factor 2 file
    Does anyone no where I should be looking it's the only sim I've never been able to patch..
    Cheers
  13. Magus
    Magus New Member
    87Coins
    Just go into your BIN32 folder and create a new folder called Plugins.
    SO the path is :
    X:\SteamLibrary\steamapps\common\rFactor 2\Bin32\Plugins
    After you create this folder it should patch.
    Basically, the Plugins folder in the BIN32 is missing after rF2 went exclusively 64-bit, that is why the patcher is not working.
  14. Evan Rowlands
    Melbourne Australia
    - 82Coins
    Hi guys..
    Where do you patch Rfactor2 I can't find and files that allow me to patch it for motion ?
  15. Evan Rowlands
    Melbourne Australia
    - 82Coins
    Ok mate I'll give that a crack I did try this and it didn't work.. but I'll try again and see how I go
    Thank you so much for your help
  16. Evan Rowlands
    Melbourne Australia
    - 82Coins
    Gday guys
    still no luck patching Rfactor 2 ive tried the bin 32 plug in folder but still does not patch
    152,241Coins
    +11,066 / 56 / -2
    So just to be clear, you have created the folder C:\Program Files (x86)\Steam\steamapps\common\rFactor 2\Bin32\Plugins
  18. Evan Rowlands
    Melbourne Australia
    - 82Coins
    Gday Mate
    No I have steam installed on my D drive so its D /steam/steam app/common /Rfactor2/bin32/Plugins
  19. Evan Rowlands
    Melbourne Australia
    - 82Coins
    Any ideas guys ??
    152,241Coins
    +11,066 / 56 / -2
    So did you manually create the Plugins folder at D /steam/steam app/common /Rfactor2/bin32/ then patch to the directory D /steam/steam app/common /Rfactor2/bin32/Plugins/
    If so what did or did not happen?
