DIY FFB Steering wheel (MMosFFB ) (In Progress)
Discussion in 'DIY peripherals' started by Alexey, Dec 10, 2015.
  1. Sel The Don
    Sel The Don New Member
    International Sales and Relations
    Bursa, Turkey
    265Coins
    Ok so I bought an STLV2 programmer - all good.
    How have people connected their encoders to the ST board?
    I don't seem to be getting any life from my encoder, in the settings menu of the EMC software I'm getting nothing from the index and encoder position.
    I have an Omron E6B2-CWZ6C running at 3.3v and 1K resistors. The Omron voltage range says 5-24v, could this also be causing an issue?
  2. Sel The Don
    Bursa, Turkey
    265Coins
    OK, so a bit of an update.
    I have everything wired up and the software installed.
    When I click re-centre in the program is the motor supposed to move back to the centre? All it seems to be doing is resetting the 0 degrees in the program.
    Going into the settings, when I try to calibrate the wheel with z index option ticked is the wheel supposed to do it's own thing like spin right then left then centre because nothing is happening. Even switching z index off is the same.
    I have everything wired up as per the diagram from EbolzMagy, using PWM mode only works on the LEFT end stop, going to the right I see the STM32 light up when it gets to the end stop but there's no resistance. I can only get it to work in 2PWM mode.
    End stops seem to be working but instead of holding in position is turns the wheel the opposite was half a turn or so, is that supposed to happen?
    Sorry for the inane questions, I've searched for a manual for the software but can't find anything so I'm having to resort to asking you fine people!
  3. Sieben
    Sieben Active Member
    2,241Coins
    No.
    Just reset, yes.
  4. Sel The Don
    Bursa, Turkey
    265Coins
    Ok thank you, I'll test it on a game later.
  5. Sieben
    2,241Coins
    Simply bumps back. That ok. Advise not to put it low. And does not mean it should hold the wheel there.
  6. Sel The Don
    Bursa, Turkey
    265Coins
    Instead of bumping it turns a quarter turn in the opposite direction to the end stop. Is there anyway that I can just make it bump?
  7. Sel The Don
    Bursa, Turkey
    265Coins
    I've been at this for over a week and it's still giving me grief.
    I'm constantly getting drift to the left, sometimes it moves slowly sometimes it hits the end stop instantly.
    I've swapped over A/B channels, still drift to the left.
    Disabling Z index has no effect.
    Moving the encoder slowly results in jerky movement over a few degrees or the software thinks the wheel is moving left.
    I'm powering my encoder with a separate 3,3v power supply, which also feeds the 3.3 volts to the encoder inputs using 1k ohm resistors.
    I'm using EMC software V1.0.5
    Can anyone help?
  8. Sieben
    2,241Coins
    Where from did you get that info on such a low voltage to the encoder? It's not supposed to work on it at all. Operating voltage is 5-24 volts. No resistors on the power line.
  9. Sel The Don
    Bursa, Turkey
    265Coins
    It's in the EMC wiring diagram, 3.3v feed, 1k ohm resistor for A,B and Z.
    Isn't the STM32 only 3.3v resistant?
    So what you're saying is that I can up the voltage to 5 volts take the resistors off?
    what about the voltage to the IBT2? stay at 3.3 or 5v ok?
    Cheers
  10. Sieben
    2,241Coins
    Don't trust everything. You should know about supply to encoder. It's written even on it. No resistor on power line. Only on the signal channels. Stm vet7 at least, has two pins. ~4.7v and 3v to power whatevers. Logic is only 3.3volts.
    With ibt, you can even go without power on it. It can be powered from motor supply only. But depends so don't mess up with it.
  11. Sel The Don
    Bursa, Turkey
    265Coins
    I don't use a resistor on the power line, I can adjust the voltage.
    So 5v to power the encoder, 1k ohm resistors on the signal line, 3.3v to ibt?
  12. Sieben
    2,241Coins
    2k ohms are better. 1k can sag the voltage. Ibt choose yourself.
  13. Sel The Don
    Bursa, Turkey
    265Coins
    You're a life-saver mate.
    Not having any drifting issues now, will test further...
    Thanks a lot mate.
  14. LuisG
    LuisG New Member
    76Coins
    Anyone using MY1016 can share what gearing ratio you are using?
    I bought 14T and 72 T pulleys but I think that might be too much specially for drift
  15. Sieben
    2,241Coins
    That's ok. 1:4-1:6 ratio.
  16. Sel The Don
    Bursa, Turkey
    265Coins
    Does anyone what the 'tweak FFB' settings does?
    Sine, Square, Triangle etc...
    The only thing I seem to be getting a reaction from is if I up the sine slider, can't really feel any difference with any of the other settings. Sine just makes the wheel go from left and right on it's own, making it unusable.
    Also, I have the FFB force at 100%, I cannot feel anything through the wheel when I'm playing R-Factor 2, only when I move sine up the slider I start to feel the FFB.
    Am I messing up somewhere?
  17. Sieben
    2,241Coins
    Does ems on stm has "constant" slider?
  18. Sel The Don
    Bursa, Turkey
    265Coins
    Yes it does.
  19. Sieben
    2,241Coins
    Pull it up.
  20. Sel The Don
    Bursa, Turkey
    265Coins
    I'll give it a try. What does the constant slider do?
